1 - 15 of 15 Posts
I have noticed some dirt build up on my car cover. It has been on the car for about a month. I took it off recently because we've had some warmer weather and all the snow is gone. I want to clean it, but it simply doesn't fit in my washer, not even close really.
So what do you do to clean one?
Mine recommends hosing it down. Doesn't really say any way to clean it exactly.. just take it out back and hose it down.
get a washer that will fit it! ;)
or...take it to a laundromat that has one of those double load washers....and wash it there. :)
btw - how small is your washer? it would fit in mine (but, then again, i have one of those huge washers).
My cover directions recommend going to a self car wash bay and putting it on a clean car and just rinsing it off that way. Otherwise, an industrial washer should do the trick.
Check manufacturer's recommended cleaning methods. Some can be washed in washer and some cleaned on car.
+1...they come with cleaning instructions. The "Weathershield" covers from Covercraft can be washed using POWDERED laundry soap in a home machine, or commercial machine if yours is not large enough. "Noah" covers are commercial wash only.
Check your manufactures web site, they should have some info on how to properly care for the fabric.
I have the Stillen cover, recommends cleaning in a washing machine. I just take it to the local laundromat.
Yep, depends upon the type. Industrial washer at laundrymat will be my move in the spring. The OEM cover I don't know about b/c I bought mine used and don't have instructions........anyone?
Okay, once you wash it, how do you dry it? :lmfao:
I'm thinking of keeping my clean cover on the Z until the spring when I bring her out of hibernation. Then I was going to hang the 'dirty' side up on the fence and spray it down, let it dry, and roll it up to keep it clean for the next round.
machine wash and machine dry. I have been doing this for many years. Only problem is most covers have some sort of scotch guard on them and it tends ot wear off when you keep washing them.
I use an extra spin cycle which greatly reduces the moisture content after washing. I then place it on a clean car and it's dry in no time.
Efficency tip: If you are detailing the car throw the cover in wash at the same time. Then car is clean, cover is clean and all is in sync.
I just got done washing my cover in the local laundry mat. Used the double washer that has three rinse cycles. Then I threw it in the dryer on high for 20 minutes. After 10 min just make sure that you reload it from the dryerto make sure that it's dry all over.
ohh man why not just hose it down with it on the car and let the sun dry it.
1 - 15 of 15 Posts
