1 - 16 of 16 Posts
I went to the car wash today after work, got some mud off, and thought I would share the pictures I took. I loooove the black wheels, and I am still waiting to see how I like 275/40s ont he front. april 25th is the first auto cross of the season.
****, those wheels and tires look huge. Looks like they're going to tear up the auto-x scene.
Oddly, your car doesn't look black in those pics.
It is all the sun glare and reflections from the trees.
I can't wait for the autocross april 25th & 26th, as well as tearing up the dragon. :shiftdrive:
Looks wicked. 275s all around, or did you stagger the back? How are the brembos working out so far?
275s on all 4 corners.
I am loving the brembos, I am not loving the noise from the carbotech pads though. I know it will be worth it when i get on the car, but when I pull up to a light and it squeaks it is kinda embarrassing.
I can't wait to change out my current pads (stockers), just trying to get the last bit of life out of them before I do the whole rotor and pad replacement job. Embarrassing as **** when you pull up to a drive-thru window and your brakes are squealing. Have you thought about trying some of that brake silencer stuff?
It is the pads themselves, it is a track pad, that squeaks when they are cold. I knew it going in. hawk HPS pads won't squeak.
I'm loving that wheel design on the moster truck....errr...your Z. :thumbsup:
What Carbotechs are you using? I'm not getting any squeal out of my Bobcats but I haven't put on my XP8's yet.
I finally got setup with my 275/40/17's all around and I loved it at the last auto-x. Front grip FTW!
I am afraid to drop it any more. The fronts have an inch or so of gap, the backs have more.
I am using the AX6 pads, they are what Justin recommended.
QUOTE ([Cerberus] @ Apr 10 2009, 06:21 AM) index.php?act=findpost&pid=573092
You're lowered now? On what? Might want to switch it up to a 35 profile tire after you wear those out. I run a 275/40 on my 17" wheels.
Slap some tire shine on that bish. :shiftdrive:
Discussion Starter · #11 ·
QUOTE (StudyBuddy @ Apr 10 2009, 09:12 AM) index.php?act=findpost&pid=573098
I mis spoke, It is stock ride height, but I am affraid to lower it with the current tires because of the rubbing.
I do plan on switching to a tire that has a 35 series 275 once I burn through these. Goodyear does not make the eagle F1 GS D3 in a 275/35 aside from their run flats, which run about 600$ a pop.
I need to get some new tires shine, the stuff I had sucked, it was a bish to put on, and did not last long. I think it was made by pinnicle.
QUOTE ([Cerberus] @ Apr 10 2009, 07:39 AM) index.php?act=findpost&pid=573102
I've been using Poorboy's BnB for years with a foam applicator pad.
http://www.autogeek.net/pbbnb16.html
Discussion Starter · #13 ·
I'll give that a shot. I have some foam applicator pads, but I found they were hard to use. I ended up using a rag instead.
Yikes!:eek:
The Z has a lot of room in the fenders. 275's should fit in there without much hassle.
If it's an offset thing, I fear it might slow you down on the track. because you may have to over-stiffen the suspension so the fenders won't squat onto the tires.
Discussion Starter · #16 ·
Yeah It was an offset thing, also a tire size thing. I screwed up ordering tires, and ended up with 275/45 in the fronts instead of 275/35. I won't make that mistake again, and am trying to find some 17s to use for autox, like a 5zigen or something cheap.
1 - 16 of 16 Posts
