My 3.58 final drive ratio isn't exactly what I'm looking for. I am into acceleration, not going 150 mph. I have seen the 3.91 ring and pinion gears, for next to 900 bucks! Anyway instead of paying 1200 for a cat back exhaust or 300 for a cold air kit, I'd rather swap rear end ratios and have the blinding acceleration I'm looking for. I know what it will do to my top end and my I know it will shorten my gears between shifts. I'm staying non FI so I will be fine.
I'm curious what other Nissans use the same center chunk. I'm guessing the Armada does. Anything else. I know the Xterra and the Frontier have a solid rear axle but the center chunk could still be the same. Nissan parts department at 4 different dealerships have been no help.
I'd like to be able to find a third member (center chunk) with somewhere around a 3.91 ratio from the factory. That way all I'd need to do is pull the axles and swap thirds.
Thanks in advance guys.
Joe
Joe
