anyone install the CDT componenets in the z? I have the CDT EF61FG and when i use the factory speaker mount to install it still hits the windows. The mounting depth is 2 3/4 inch. i believe the infinity kappa perfects in the tutorial have the same mounting depth. was there anything else added as a spacer besides the bose speaker bracket?
Thanks
I added the speaker bracket and a little bit of window caulk to seal up the air gap.
which speakers did you use? they didn't hit the window?
The Infinity Kappa Perfect Speakers BARELY cleared the window. If you push the speaker out much more with a spacer it will hit the door panel.
I first used the cdt 61 something or another, it is a tight install but with the rope caulk you can shim out the speaker (slightly towards the rear of the car) and it will clear. And take off the rubber magnet protector
