TOYKILLA,
Thanks man, your the best!!!!!!!!!!
Originally posted by stopgo@Aug 22 2005, 08:27 PM
Hi Toykilla,
I've purchased the following speakers for my car and need some advice on how to drive them.
Boston Pro60 Components
power range: 2-125 watts RMS (150 watts peak power)
frequency response 50-22,000 Hz
sensitivity: 90 dB
Boston G21044 10" DVC 600W
Rated RMS power handling 300 watts
Nominal Impedance Dual 4-ohm
Recommended Enclosure 0.5ft ³ (14.2 L) volume sealed
I'm looking at the following amps:
For the components...
Boston GT-40 AMP 460W AMPLIFIER GT40 4 CH
Multi-Ch. Power @ 4-ohm (12.6VDC) 4x45W
Multi-Ch. Power @ 2-ohm (12.6VDC) 4x70W
Dual-Mono Power @ 4-ohm(12.6VDC) 2x140W
Dual-Mono Power @ 2-ohm (12.6VDC) 2x175W
Mixed Op. Power @ 4-ohm, 2ohm (12.6VDC) 2x45W, 1x190W
Mixed Op. Power @ 4-ohm, 2ohm (14.4VDC) 2x55W, 1x240W
Frequency Response (-3dB) 10Hz-95kHz
Signal to Noise Ratio (A Weighted) >100dB
And the sub...
Boston GT-28 SUBWOOFER AMP 500W GT28 2 CH
Multi-Ch. Power @ 4-ohm (12.6VDC) 2x75W
Multi-Ch. Power @ 2-ohm (12.6VDC) 2x135W
Dual-Mono Power @ 4-ohm(12.6VDC) 1x275W
Dual-Mono Power @ 2-ohm (12.6VDC) 1x390W
I'm completely retarded where this stuff is concerned so I'd like to know if the amps I'm considering are over/under powered (I'm just not sure which numbers I need to be comparing). The amps are manufactured by JL despite the Boston badge, so if there's a less expensive JL alternative that would be cool, too.
Thanks!
[snapback]148198[/snapback]
Originally posted by EriksonFL@Sep 15 2005, 01:17 PM
Will the steering wheel controls from an Infiniti FX plug into my Z's bose head unit.
[snapback]155308[/snapback]
Originally posted by TOYKILLA@Sep 15 2005, 07:05 PM
Did you make spacers out of the stock speakers like i did in my tutorial?
The problem IS the depth of the speaker. The window rolls down behind the speaker, so the deeper the speaker, the better chance of clashing.
1" spacer may be too deep. If you follow my tutorial exactly you will see i had to shave part of the door panel (inside, not visible)
[snapback]155388[/snapback]
I'm not really sure. I bought it used and purchased the extended warrenty for 6yrs 100,000 mi so it should be, but i dont know if the radio is covered. If not, aftermarket here i come! :irock:That sounds like a bad head unit. is it still under warranty?
I had the Bose in dash 6 cd changer in my QX4 with the same problem. $325 to fix from the dealer. From what I read, it seems pretty common. I also hear they are actually Clarion cd changers. The speakers and amp is Bose.Hello all
I was wondering if anyone has had problems with the Bose 6 disc changer, more specifically none of my cds will play and i get a message that says check disc. I know the discs are good and it does this in all 6 slots. Thanx in advance
