Are there any 350z wiring diagrams?
I'm going to install a new HU, speakers, and multi-ch amp behind the drivers seat.
I'd like to understand the wiring since I haven't done this before.
Here are my initial thoughts:
- 3 RCAs from the HU to the amp (3 for upgrade, only use 2 for now). Runs through the center hump.
- Speaker wire from amp to fronts. Run through center to dash and across to each door???
- Speaker wire from amp to rears. Run through rear area. I assume this is obvious.
- Amp power. Run to battery via right side under carpet on floor. Inline fuse soon after battery.
- Amp ground to chassis in compartment.
- HU RCA input - Probably will run to the back just in case. Might want to find a Sony Bus control cable to control changer if desired in future.
- HU hardness via adapter to factory harness. I ordered one of these from Crutchfield but not sure I need it. HU has:
1. Ground (duh)
2. Antenna Remote (Power antenna control lead or booster amp) NC right?
3. Amp Remote In. This goes to Amp turn on??
5. Illumination. Dunno where this goes??
6. +12V (ignition on). Connect to Cig lighter? or fuse box (which?)
7. +12V (battery).
8. Car antenna.
OK, am I missing something?
