After some absence from tuning forums... I'm back. (kept the Z stock for all these years... unfortunately it's worth nothing now considering the low KMs. So I'm keeping it until it's a relic in the bush)
Looking for a track set-up and I hatched this idea from different sources. Wanting to know if it can be done. Wanting it to be square as posible.
275/40/17 on the front with a 10.5" wide rim.
275/40/18 on the rear with a 11" wide rim.
I have a VDC so I want the rotations to be roughly within a 1% margin from stock. (-1.2% front, -0.1% rear). Also wanting to stick as close to the factory +30 offset because I don't plan on changing the suspension except for sway bars. It's a '03 anyways.
Plan 'B' if the fronts don't work is 255/45/17 on a 9.5" wide rim. (0.2% rotational difference from factory)
any input?
Thanks
any input?
Thanks
