I belive so
Yes, it is a straight forward bolt on install. Just be sure you get the track rear caliper mounting bolts, as their pitch is different. Also, you will need to remove, cut, or replace your rear backing plates. You will probably also have to snip away a bit of the front backing plate. I'm not sure as I run 13" F Stoptechs.
Yes, it is a direct replacement. Everything BCRLtd said above is true.
