OK. Not sure if this is the correct place to post this but ----I just moved over from the "other" 350z site and am not getting a lot of response to this. So, here it goes---this is going to be a bit long but I do not know how else to talk about this. I have an 04 touring with stock 17" wheels/tires--until 1 week ago. I upgraded to front 245/40/18 and rear 265/40/18. Had the car aligned and rechecked. when I was washing my car the other day and looked at the rear wheels from the rear of the car I noticed that --the rear wheels had a very pronounced negative camber that was very plain to see. in fact the outer 1 1/2 inch of the tire was hardlly touching the ground. You could see road dirt on the inside 3/4 of the tire face/tread and the outer 1 1/2 inch of the tire face/tread was clean. Springs are stock. Now my original question was should I be concerned and do I have to worry about uneven tire wear problems in the rear. If there is anyone out there that understands the the Z suspension then I would appreciate a response.
Now for the next question related to this---If this seems like a dumb question--sorry but we all have to learn. I noticed that right after I had driven the car on a flat, even road and stopped on the road look at the rear wheels, the wheels did not appear to be showing as much negative camber as before in my drive way. Is it possible for the tires to "spread" when going over a large sloped curb at an angle into a drive way and stopped and remain at what appears to be an excessive negative camber. and then when you drive them again, they pull back into "line" ? does the question make sense? By the way, I had my rear aliignment checked this afternoon and both rear wheels are set to -1.3 degrees--- within the factory range.
