Originally posted by DiRN@Oct 29 2004, 02:44 PM
No, BHP is the same was WHP
Originally posted by Jetpilot718@Oct 29 2004, 07:32 PM
Actually, I'm about 99.9% sure BHP is measured at the engine... through use of an engine-dyno like this one:
Originally posted by SmoothZ@Oct 29 2004, 03:06 PM
Avg HP loss from crank to wheels is around 20%. Or you could take 80% of crank HP and that's the wheel HP.
Originally posted by thrlskr+Nov 7 2004, 07:42 PM--><!--QuoteBegin-SmoothZ@Oct 29 2004, 03:06 PM
Now I know you said AVG but...
This is a merely internet tribal wisdom. Without into getting into why, let's use common sense.
Example (using arbitrary numbers):
Take a 300hp engine HP rwd car and it dynos at say 240rwhp using your theory. No problem.
Now turbo or supercharge it and hypothetically add say 100 engine hp. This car would now dyno at 320rwhp using the 20% drive train loss factor. Does this make sense? Why should the driveline suck up an additional 20hp? No driveline changes were made! Assuming you did add 100hp then you should dyno at 340rwhp.
The reason is simple. It takes a certain amount energy to turn the driveline and some drivelines are more efficient by design than others, but the amount of energy that it takes to turn is a constant. If it takes 60hp to turn the driveline it will always take 60hp to turn that same driveline. Using an arbitrary rule of thumb to apply to all cars doesn't make sense.
BTW, BHP stands for brake horsepower.
Just my $0.02,
