1 - 20 of 22 Posts
Okay... this weekend at the Triangle Z Club/Triad Z Club show, I was finally able to sally up the BY next to a new IF Z. Unfortunately, the dealership had moved another Z in the way of the coupe, but I was able to put my car directly next to a drop top IF Z for comparison. Shots follow.
The quick and dirty... the colors look strickingly similar in only two instances. Indirect, high afternoon daylight and in the shade, both have similar appearances. In all other lighting (low level light, low light, direct light, blah, blah, blah... they are very different).
First up, some pics of just the IF roadster. (apologies if these don't look as clear as I describe, I'm having or resize to meet forum requirements.
In this photo, panels nearly parallel with the sunlight appear very brickyard-ish, but the areas where sunlight is reflecting strongly take on a coppery-brown hue (note back of car)
Discussion Starter · #2 ·
As you move around so that you catch more of the reflected sunlight, the coppery brown transition to more of a baby-sh!t brown.... not my words, I believe Bryan coined that. In any case, I tried to capture this with the camera, but really couldn't get it perfectly. Here you can see the how the color changed by me moving the camera angle 45 degrees toward the front of the car.
Here is a close up to give you a better idea of the copper flake effect and the brownish appearance.
Compare that to similar lighting on my car (this photo was from a different day)... you can see much more black metalflake in BY vs copper in IF...
But, as you can see in this color, at times the IF looks very similar to BY. The question is, tho... just how similar is it?
To answer the question above, I rolled my BY along side the roadster and took some shots.
This is late afternoon light. You can see the similarity in color, but the BY has a distinctly darker/redder hue. Again, the only way I can describe the IF is that it is more 'coppery'.
at this angle, you can see where the lower black metal flake content of the IF results in a more "purple" appearance than the BY. The BY is, again, clearly darker looking in this light. Where the whole area behind the wheel on the IF roadster appears radiant purple, only the line precisely where the sun is hitting appears so on the BY.
Discussion Starter · #12 ·
vs. the BY 1/4 at as close to the same angle as I could get. These pics were taken 10 seconds apart. It's very apparent here the difference in metal flake content of the two colors...
Discussion Starter · #14 ·
finally, these two specimens. Not the same exact same elevation, but the side angle is about right. In any case, enough to illustrate the difference between the two... IF here...
Discussion Starter · #16 ·
My conclusions...
I believe the two colors use the same base color. The similarity in certain light is too close for it not to be the same.
The real difference is in the metal flake. Not only is there a difference in metal flake color (Brickyard has a large content of black metal flake vs IF's large content of copper metal flake), but IMO Brickyard has more flake and a coarser grain of metal flake. This is most evident in the close up pic I posted of the taillights taken from the door angled toward the back of the car (3rd and 4th posts in this thread). The color and amount of metal flake is clearest for both cars in that pic.
I cannot overstate, tho, the baby-sh!t brown effect you get with IF. It doesn't show up well in any of my pics, but I heard lots of folks comment on how 'brown' the IF looked. I've heard BY called a lot of things, but never brown.
Anywho... hope that helps anyone trying to discern the difference between these two colors.
Discussion Starter · #19 ·
well from far away they look the same
but up close yes, the interlagos fire looks like brown
I wish I could have captured the baby sh!t brown effect. It really appears that way from a distance also. Like BY, it all depends on the angle and intensity of light hitting it. I can see it being mistaken for BY, but it won't take an expert to notice the difference if the lighting is right, either.
1 - 20 of 22 Posts
