1 - 1 of 1 Posts
*Sizes in parentheses are inches, all others are MM*
GENERAL SPECS
Front
Brake model (OEM) CLZ25VD
Rotor outer diameter x thickness: 296 x 24 (11.65 x 0.945)
Pad length x width x thickness: 125.6 x 46.0 x 11.0 (4.94 x 1.811 x 0.433)
Cylinder bore diameter: 57.2 (2.252)
Brake model (Brembo) OPB27VA
Rotor outer diameter x thickness: 324 x 30 (12.76 x 1.181)
Pad length x width x thickness: 117.1 x 53.3 x 9.3 (4.61 x 2.098 x 0.366)
Cylinder bore diameter: 38 (1.50) x2 + 44 (1.73) x2
Rear
Brake model (OEM) AD14VE
Rotor outer diameter x thickness: 292 x 16 (11.50 x 0.63)
Pad length x width x thickness: 83 x 33 x 8.5 (3.268 x 1.299 x 0.335)
Cylinder bore diameter: 42.86 (1.6874)
Brake model (Brembo) OPB13VB
Rotor outer diameter x thickness: 332 x 22 (13.07 x 0.87)
Pad length x width x thickness: 76.6 x 45 x 9.1 (3.016 x 1.77 x 0.358)
Cylinder bore diameter: 40.0 (1.575) x2
Master Cylinder (all)
Cylinder bore diameter: 26.99 (1.0626)
Control Valve
Valve model: Electric brake force distribution
Brake Booster
Booster model: V255
Diaphram diameter: 255 (10.04)
Recommended brake fluid: DOT-3
BRAKE PEDAL
Brake Pedal Height (from dash panel top surface)
A/T model: 162-172mm (6.38-6.77in)
M/T model: 154-164nn (6.06-6.46in)
Depressed Pedal Height (under a force of 450N (50kg, 110 lbs) with engine running
A/T model: More that 95mm (3.74in)
M/T model: More than 90mm (3.54in)
Clearance between the stopper rubber and the threaded end of the stop lamp switch and ASCD cancel switch: 0.74-1.96mm (0.0291-0.0772in)
Pedal play: 3-11mm (0.12-0.43in)
1 - 1 of 1 Posts
