The 2006 models received larger brake rotors. Did the track model brakes also increase in size?
I have the sizes listed for the brakes as:
Standard
2003-2005
front - ?
rear - ?
2006-2007
front - 318mm x 28mm (12.5" x 1.10")
rear - 307mm x 16mm (12.1" x 0.63")
Brembo
2003-2005
front - ?
rear - ?
2006-2007
front - ?
rear - ?
Found the "selection guide" for my 05;
200?-2005
Standard
front - 11.7"x0.95"
rear - 11.5"x0.63"
200?-2005
Brembo
front - 12.8"x1.18"
rear - 12.7"x0.87"
200?-2005
Standard
front - 11.7"x0.95"
rear - 11.5"x0.63"
200?-2005
Brembo
front - 12.8"x1.18"
rear - 12.7"x0.87"
I believe you're correct about those sizes for the standard.
Edit: I meant you are correct about that size. I knew mine were between 11 and 12 inches.
Discussion Starter #4
2006
Standard brakes
Power-assisted brakes — 12.6" x 1.10"
vented front discs and 12.1" x 0.63" vented rear discs
Brembo® braking system
4-piston caliper with 12.8" x 1.18" vented front discs and 2-piston caliper with 12.7" x 0.87" vented rear discs
2006
Standard brakes
Any idea of the weight of the Brembo system? I am currently looking to upgrade mine with new lines and rotors. I would like to go lighter if possible. Stoptech or RacingBrake. I have seen different sizes also from 326mm, 328mm and 330mm X any where from 22 to 28 or 30. Somthing like that. Do you know the purpose for the diff sizes?
