1 - 20 of 27 Posts
Short and simple. Do you have Borla with non-resonated test pipes? Is there a raspy sound?
I have resonated ones but the weld came apart and i am thinking about going with non-res pipes..
The rasp depends on the thickness of the steel they used to make them.I noticed the early HELIX ones I had were raspy but since they have thickened the SS and are not as raspy. The thicker the SS the less rasp.
i know with TT the raspiness is almost gone, however with NA u still feel it
Josh, is the rasp sound all the time? or for a small period, then it goes away as u speed up?
WOW! didn't you just install your test pipes? I just installed mine this weekend with my Borla will discuss it later when I have more time. The Borla is for sure louder than stock especially in the car I like it but gonna take some getting used to think im gonna dynamat the doors and truck.
hmm no rasp but i hve resonated pipes. josh i had to have parts of the exhaust welded to prevent the noise
the rasp has nothing to do with the welding.. i do not have rasp right now with resonated pipes, but they are cracked and i am considering non-resonated ones.
i have helix test pipes, and to bam, why the heck wouldyou want to add all that weight with the dynomat??? that kinda messes up the whole idea of getting a performance exhaust doesnt it? **** i want mine as loud as possible, i was considering getting rid of the resonaters in the borla to louden it up, on a side note, between the test pipes, borla dual catback and aem cai, the test pipes were the biggest difference :) as well as the cheapest.. just fyi
IMO, resonated TP = :flush: waste of money (at least for those in non-carb states).
I have the Helix pipes and don't mind the sound at all. The 'rasp' only lasts for a second or so.
Discussion Starter · #14 ·
disagree.. i prefer resonated with stock exhaust..
throw an aftermarket Y-pipe on your exhaust and let me know how bad the rasp is. On a stock exhaust, resonated or unreseonated, it doesn't matter much. You mix into the equation an aftermarket Y-pipe and it is RASP city. Sounds absolutely awefull.
With the borla, I wold think you would be fine with a good set of unresonated TP.
Discussion Starter · #16 ·
agreed.. i put a ypipe on with resonated test pipes and it sounded horrible.. pulled it off immediately
ok I added non resonated test pipes to my Borla tru dual. And I think it sounds horrible... Its sounds badass when your parked and just raising the rpms but I think it sounds too riceee when ur haulin'. Love the increase in power first time my car started scratching hard(almost loose control) in 3rd gear. is there a way to add resonators to the test pipes.? :doh:
Discussion Starter · #19 ·
yes and no, you can add resonators but it would cost you more than just buying resonated ones
Has anyone tried the Borla TD with the Borla test pipes?? How does that sound?
1 - 20 of 27 Posts
