Hi, how are you?
I need some of help. I have a 350Z (2005) european version with bose HU and amplifier original and i need to install a parrot ck3100 bluetooth. I have a question for you, need i install any independent speaker? some body tell me that yes but i dont know
Thanks a lot
REGARDS
Aloha,
Check the install manual. If an output wire on the bluetooth device goes to a speaker output, you may not require an external speaker. Would have to see the wiring schematic of the parrot and HD to give you a good guess.
A Hui Hou
PaulO
That bluetooth unit is made specifically to use the cars speakers, there are some others made by parrott and nokia, etc... that come with an external speaker. This unit will automatically mute the radio and connect to your car speakers when you answer. The next best thing is a unit Alpine is putting out next month that has bluetooth integrated into the actual head unit so you won't need an extra component to mount on the dash. That's my next move, I'll have pics in 4 weeks hopefully. Good luck with the install.
Here is an email address to contact parrott direct if you have a problem.
[email protected]
found that @
http://www.gotbluetooth.com/bluetooth-aces...ne-T-Style.html
