I've been searching for a while and keep coming up short on BBK sizes and weights. Here's what I have found so far. I'll update as I continue to come across data. Happy for corrections/info to be posted in here too.
OEM Brembo
Size:
Front caliper: 4-pot
Rear caliper: 2-pot
Front rotor:
Rear rotor:
Weight:
Stock Akebono (Sport Brakes 370z):
Size:
Rear caliper: 2-pot
Front rotor: 355mm
Rear rotor: 332mm
Weight:
Front caliper: 11lbs
Rear caliper: 6lbs
Front rotor: 29lbs (1-piece)
Front DBA rotor: 22lbs (2-piece)
Front Rentless Autosport rotor: 19lbs (2-piece)
Rear rotor: TBC
AP Racing:
Size:
Front caliper: 6-pot/4-pot
Rear caliper: 4-pot/2-pot
Front rotor: 363mm/332mm
Rear rotor: 332mm
Weight:
Front Caliper (6-pot): 7.3 lbs
Rear caliper (4-pot): 4.7 lbs
Front Rotor: 20.3 lbs
Rear Rotor: 22.8 lbs
Stoptech:
Size:
Front Caliper: 6-pot (ST-60)/4-pot (ST-40 or ST-45 with 380mm rotors)
Rear Caliper: 4-pot (ST40)/2-pot (ST-22)
Parking Brake: 1-pot (ST-10)
Front rotor: 380mm/355mm/332mm
Rear rotor: 355mm/332mm
Weight:
Front Caliper (6-pot): 8.5lbs
Rear Caliper (4-pot): 7.94lbs
Front 380mm: 21lbs
Rear 355mm: 19lbs
Front Caliper (4-pot): 7.94lbs
Rear Caliper (2-pot): 4.4lbs
Front 355mm: 18lbs
Rear 332mm: 15lbs
Parking Brake: 4.13lbs
Alliance:
Size:
Front caliper: 8-pot/6-pot
Rear caliper: 6-pot/4-pot
Rear rotor: 355mm/322mm
Weight:
Front Caliper (8-pot): 6.50lbs
Rear Caliper (6-pot): 5.95lbs
Front 380mm: 21.00lbs
Rear 355mm: 21.75lbs
OEM Brembo
Size:
Rear caliper: 2-pot
Front rotor:
Rear rotor:
Weight:
Size:
Rear caliper: 2-pot
Front rotor: 355mm
Rear rotor: 332mm
Weight:
Rear caliper: 6lbs
Rear rotor: TBC
AP Racing:
Size:
Rear rotor: 332mm
Weight:
Stoptech:
Size:
Weight:
Front 380mm: 21lbs
Rear 355mm: 19lbs
Front 355mm: 18lbs
Rear 332mm: 15lbs
Alliance:
Size:
Weight:
