21 - 24 of 24 Posts
i know what the rattle is...ive had mine in for about 4 months now...
its a problem with the design
the shifter is two peices ...the shifter slides over the bottom part of the shifter and then there is a bolt that goes through them and holds them together
there are a bunch of orings in there to keep them from chattering against each other...they crack...when i took mine apart i found broken o ring all over the place....so i took teflon tape and ran it up and down the inner shaft a couple of times and its alot better....
oh by the way it gets louder over time....
but like i said teflon tape helps alot
hope this helps fellas
tony
Maybe it's the alignment plate, i have mine all the way to the driver's side, i'll try to slightly move it to the passenger side, we'll see if that helps.
21 - 24 of 24 Posts
