Status
Not open for further replies.
1 - 1 of 1 Posts
I had a few items lying around after my install and just need to get rid of them now. I thought I'd give you guys a try first to see if anyone is interested here. Almost every item is brand new- check it out, maybe you could use something...
Prices:
20ft. Crankin' Cables 2awg power wire- $20
Monster Cable PowerSplit Dist. Block (one 4awg input->four 8awg outputs)- $25
Monster Cable PowerSplit Dist. Block (one 2awg input->three 4awg outputs)- $25
16.4ft. Rockford Fosgate Premium Signal Cable CPM-500- $30 (This item had to be repaired slightly by soldering at a small joint, but tested after and it works perfect)
1.6ft. Rockford Fosgate Premium Signal Cable CPM-100- $15
Monster Cable Quick Lock Gold-Plated Speaker Wire Connectors- $15
Radioshack Gold-Plated Phono-Phono Adapters[have 2]- $3/each
8awg Gold-Plated Spade Terminals from local car shop[have 6]- $2.50/all
Soundquest Wire Gauge Reducer (4awg->8awg)[have 2]- $2/each
Lightning Audio -Bolt- Gold-Plated Power Ring Terminals, Pair- $5
Rockford Fosgate Punch 1.0 Farad Capacitor w/broken bolt in one of the terminals- $10
And a pair of Stock tweeters, if anyone's interested!- $?
Thank you all for checking out my post! Local pick-up also available. Northern NJ.
Additional pics to follow...
1 - 1 of 1 Posts
Status
