I'm interested in putting in a new HU, speakers, subs, and of course i'll need amps for both. Does anyone have any tutorials on the best way to run the wiring kit throughout the car? I've got an 03 Coupe.
Here you go,CLICK ME, I used these and didn't have a problem. Good luck to you and you suck becuase you get to take the Z on the Autobahn :yourock:
You will need to run the power wire from the battery through the firewall (there is a rubber gromet behind the battery that works great.).. then run it down inside the kick panels and along the door jam (under the carpet). Then feed it either under the seats or into the glove compartment area and to wherever you want. You can run speaker wires right up the center of the car past the shifter (under the big plastic center console.
If you run the the wires along the door jam where do you run it to go into the glove box? Do you have to remove the side panels to do this?
