Super Moderator
Welcome, Bob. Whether you look at the fuse box (in the DS footwell) or the IPDM (under the PS cowling), look at the diagram on the cover that show where each fuse goes. Has it always been this way? Or when did your audio go out?
Found the fuse box and the fuse for the radio. Put in a new fuse and radio worked great--glad it was something so simple to fix!
Super Moderator
Glad it worked out, but you're only halfway fixed. You still need to determine why that fuse blew in the first place. Is it a worn wire that is causing a short? Maybe internal circuitry in the headunit itself? Any clues as to why it happened in the first place?
