I just finished changing my tranny fluid to RedLine MT 90 and saw that my drain plug is at the bottom of the tranny. On other posts I read that the drain plug is on the side and that you need to pump out some of the old fluid. My drain plug is at the bottom and the filler plug is at the passenger side. Changing the oil was a brezze.
My tranny also took 4 WHOLE quarts. The other post says it takes 3 1/4 quarts. Car does shift a little better now but its not a huge improvement. Rogue shifter install is next. Are there two different trannys? I have an 04 Enth.
