1 - 9 of 9 Posts
You don't need high flow cats w/ the Borla but you CAN use them if you WANT. I have the Borla TD Catback Exhaust and stock cats. Been on there almost two years, and she is fine. It really has a nice sound too.....:biggrin: Not ricey a nice growl or purrrrrr :shiftdrive:
Originally posted by jinxxycat@Aug 5 2005, 10:53 AM
What is confusing tho?  The pieces?  It says "hard" to install, but I did it myself w/ my hubby, it was piece of cake (with lift and air tools) an hour and a half to take OEM out and put Borla in :thumbsup:
[snapback]142045[/snapback]​
so what will be the outcome...since i already have Kinetix High Flow Cats installed
or is there a better alternative
I think you would be just fine. I would say the outcome would be a better sound, better breathing, no problems. They should match up as far as diameter goes. With the cats and the intake you should upgrade the exhaust IMO, complete the system! :biggrin:
You should be good man. The Kinetix cats and the Borla should bolt up perfectly. I'd suggest replacing the gaskets while you're down there though.
I'd also suggest getting it onto a lift if you have access to one. Just get it as high off the ground as you can. It'll be a lot easier than laying on the concrete.
[snapback]142063[/snapback]​
wow.....thats great then
:clap:
It will be fine, if, just in case, it isn't, just buy a flange to adapt it.
[snapback]142343[/snapback]​
thanks for the advise
love that stang!!!!
1 - 9 of 9 Posts
