Peter let this little nugget drop on the other forum.
"When APS releases the Single Sidewinder Intercooled Dual ball bearing Turbo system you will then see it's possible to have a much broader Power and Torque range when you use much improved exhaust manifolding which retains more of the heat energy to drive the turbocharger."
I doubt it would be designed to pass ADRs as it probabally removes the stock cats. So I wouldnt hold your breath if your Australian but its always good to hear of other 350z products.
