41 - 47 of 47 Posts
****, HID were on the top of mods to do list :( So you can't buy a HID kit for $150 off ebay and replace the factory bulb?
Hey guys,
The wiring layout is posted below:
03 non-HID
(This is looking into the plug on the headlight)
6 Pins labeled like below
1 2 3
4 5 6
1 - Black (Ground for Low and High Beams)
2 - Light Green (Positive for High Beam)
3 - Green\Black (Positive for Turn Signal)
4 - Red (Positive for Low Beam)
5 - Green\White (Positive for Parker lights)
6 - Black (Ground for Parkers and Turn Signal)
This is the layout for both sides...
06 Bi-Xenon Pin out
8 Pins labeled like below
1 2 3 4
5 6 7 8
4 - Red (unknown)
5 - Black (Ground for Parkers and Turn Signal)
6 - Red (Positive for Low Beam)
7 - Green\White (Positive for Parker lights)
8 - Blue (unknown)
This layout is the same for both sides...
pin 4 and pin 8 : these are used to tilt the projector up slightly when the high beams are activated. I didn't use these with my setup as I cound't find any info about them in the wiring diagram.
Yes they are LED parkers. I didn't like the blank plastic bits so, I made the LED parkers.
Did you have any trouble with the blinker flashing really fast
Ok I just bought some Depo +6 headlights from eBay and also bought a pair of hids cause my 350z is an 03 and a base model. I've had the headlight on for about a month and now the driver side headlight is getting worse it's takes a lot of off and ons to get both of them to turn on sometimes I get lucky but now only the passenger side turns on!
I have a similar issue
I have an 03 base and I got some depo headlights and bought some hids and my driver side hardly turns on it's always my passenger side light that's good but my driver side hart turns on! It'd be great if someone could help me out
41 - 47 of 47 Posts
