here are a few pics of my ALPHAWERKS headers from NEXUSINDUSTRY.COM
I will have more pics of the install later as well as some other info on the install itself. I will try to dyno this upcoming week.
the install was a task but well worth effort. My buddy Harrry and I had no problems with anything during the install. Harry had done a header install on his Z so i was real comfortable with him and his work. total time for install was @7 hours. it can be done quicker but we took our sweet time, that is the way i like to do things.
i haven't reset my ECU yet but here is what i have observed so far: my 3rd gear pulls VERY hard. Top end power delivery feels GREAT. the sound is only a bit louder than w/out the headers. the exhaust note changed only a bit but still sounds very nice.
more to come stay tuned!!
BIG shout out to Harry for all of his help and expertise!!!!!
Discussion Starter · #2 ·
The instructions that came with the headers were very detailed but did not state that two additional bolts and nuts were needed. each factory exhaust manifold has one stud. also, i didn't see anything in the instructions about removing a coolant pipe (pic below). other than that, the install instructions were accurate.
*make sure to have all the necessary tools before the install.
*make sure you have time for the install, don't rush it. it took us @7 hours.
*make sure to either save your coolant in a clean container or just buy some more coolant and distilled water. I did the latter
*make sure to have a sharpie or a white paint marker to mark your drive shaft before disconnecting it.
*install the headers and the cats together, this will save some time. *becareful with removing and reinstalling the O2 sensors.
*becareful with the exhaust manifold gaskets.
*it is hard to use a torque wrench on the header bolts. we just used good ol' german torque, good 'n' tight. on my buddies Z's both their headers studs showed five threads, as my headers did once torqued down.
*fender covers will help protect your paint
*make sure to tighten every bolt and every connector that was either loosened or disconnected
*once finished the vehicle will run hot till the 1st heat cycle passes. it might take short while. once the thermostats reaches temp and opens, the car will draw coolant into the sytem. fill radiator and resevoir accordingly
you WILL have cuts and scrapes all over your forearms and hands. my advice on that one is cowboy up! LOL
Enjoy your Headers
here are a few more pics of the install
screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt='Click here to open new window';}" onmouseover="if(this.resized) this.style.cursor='hand';" onclick="if(this.resized) {window.open('http://memimage.cardomain.net/member_images/9/web/609000-609999/609852_322_full.jpg');}" />
screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt='Click here to open new window';}" onmouseover="if(this.resized) this.style.cursor='hand';" onclick="if(this.resized) {window.open('http://memimage.cardomain.net/member_images/9/web/609000-609999/609852_323_full.jpg');}" />
screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt='Click here to open new window';}" onmouseover="if(this.resized) this.style.cursor='hand';" onclick="if(this.resized) {window.open('http://memimage.cardomain.net/member_images/9/web/609000-609999/609852_320_full.jpg');}" />
screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt='Click here to open new window';}" onmouseover="if(this.resized) this.style.cursor='hand';" onclick="if(this.resized) {window.open('http://memimage.cardomain.net/member_images/9/web/609000-609999/609852_321_full.jpg');}" />
