Alignment for lowered Z
811 Views 4 Replies 3 Participants Last post by  MicVelo
I need an alignment because I'm chewing through front tires but every shop (10? Different shops) say my car can't be aligned because its too low? Is just impossible to align a lowered car? My z is on kybs and D2 lowering springs if that helps
Sent from my SM-G975U using Tapatalk
Can't speak to D2 springs, but with my Eibach Prokit springs, I used additional suspension components to keep my Z in alignment specs.
Its stock suspension besides the lowering springs. I believe its has a toe issue. I am wearing out tires on the inner side of the tire, down to the belt, within spring-fall driving season.
Toe is about the only thing that can be adjusted stock correct? So you are aligning everything yourself? Ive watched a bunch of DIY alignments on youtube thinking I might take a stab at it.
Depending on how low your springs take you, camber may be so extreme that you'll wear out the inside of your front tires no matter what you do. Have you looked into some adjustable front upper control arms? SPL makes a nice set:
SPL 350Z / G35 Titanium Series Front Upper Camber Arms - Z1 Motorsports - Performance OEM and Aftermarket Engineered Parts Global Leader In 300ZX 350Z 370Z G35 G37 Q50 Q60
Definitely a combination of toe as well as caster and camber. Not hard to see why. Lowering a car changes all of the suspension angles naturally. Bringing it back into spec (or to your desired performance spec), you need adjustability, something lacking in the stock suspension.
Adjustable FUCAs (front upper control arms) are REQUIRED for any lowered Z. SPL is top of the line but if you aren’t racing, you don’t really need them (plus they’re very $$$). Consider SPC as a good street/hills/track day alternative. I don’t usually recommend any of the others as SPL and SPC do NOT require any disassembly for adjustment.
