I bought a grille-tech insert when I first go my Z and last year at the Atco event, I saw a Z that had a machined bracket with hex screw vs. the tie wraps.
after doing a few mods, I have cut and replaced the tie wraps which frequently are a PITA!
I have searched for the long screws.....anyway, finally found on line from front-grill who makes a competative grille - they have a bracket set for $13. If you order from their website, it will only show S2000 brackets, you need to put that you have a 350Z in the notes area. www.front-grille.com
so here is the bracket and Now I can take the insert on and off with the turn of a hex driver!
