1 - 10 of 10 Posts
Super Moderator
Why don't you post a few more details about your Z so we can start providing better answers for your querries? Has it always done this? How many miles on this Z? Any codes showing up?
09 370Z accelerate sometimes by itself and is now start cutting out sometimes...i cleaned everything Round throttle body...and I putin new cam sensors and and mass sensors I ordered a new map sensor..i replace my OEM VACUUM SOLENOID VALVE SWITCH with a use one..i have some o2 sensors coming in now
Discussion Starter #4
I did alot upgrade...like exhaust ..test pipe bigger injections..its alot more things im waiting on check engine light come back on after. I clean every I unplug my battery to See whats the problem...
Super Moderator
You're welcome. P0507 means the ECM is detecting an erratic idle. Here's some possible solutions from the FSM:
  1. Replace or clean the idle air valve.
  2. Repair a large intake air leak.
  3. Repair the charging system.
  4. Clean the throttle body.
  5. Replace the power steering pressure switch.
Discussion Starter #9
Thanks for saying ....i change my map sensors, both pvc valve and both can shaft sensors now in just wanting for valve cover gasket to come and I let u know wuz up and how its running
1 - 10 of 10 Posts
