Here's another '350Z vs ...' thread moved from my350z. This time the350Z is matched up with an Astra Turbo.
Acceleration Compariosion:
- Test #1: 0-130kph, standing start:
We did this a few times but the Zed will always out launch the Astra ... RWD helps here. The Zed jumps about 1 - 2 car lengths ahead even when the Astra gets a good launch, and then pulls away like a train. The Zed had good 3 car lengths by the end of 1st gear, and pulled even more in 2nd gear. By the time I shut down at around 130kph, I was good 6 - 7 car lengths ahead. Even if I bogged down at the start, it just meant that the Zed needed 1 - 2 secs to catch its breath and start pulling away.
- Test #2: 5-130kph, rolling start, both cars in 1st gear:
Again the Zed starts pulling away as soon as we started. It's pulling away pretty convincingly, but not as quickly as from a standing launch ... it's a lot more gradual. Still, by 130kph I would be good 4 - 5 car-lengths ahead. The Astra has a decent bottom end (which shows by its peak torque of 250Nm at ~2000rpm).
- Test #3: 10-130kph, rolling start, both cars in 2nd gear:
I was expecting to see a bigger difference than in the 1st gear roll, but surprisingly it was not much different to the above scenario. Because there are no gear-changes involved until ~100kph, it demonstrated the power difference pretty well, and the Zed pulls away more and more as the speeds increase. Again, by 130kph the Zed was good 4 - 5 car-lengths ahead.
- Test #4: 0-170kph, standing start:
I was interested to see how the Astra would go a higher speeds, and it did pretty well as I was expecting it to run out of puff there. Anyway, as in the 1st test, I would always out launch the Astra and then just consistently pull away. It was no different to 130kph from the 1st test, but after that I pulled away another 4 car lengths or so before I shut down at ~170kph. That would put me about 11 - 12 car lengths ahead ... hard to guestimate that kind of distance, but it was a fair bit. Still, the Astra was pulling pretty hard even at those speeds .... from what I gather, the Astra would be doing 150 - 155kph at that stage. That is not too far of a WRX.
Astra Turbo Impressions:
- The car feels petty good too even though it is more tuned for comfort and refinement (ie. very quiet, smooth and relatively soft).
- It has a good engine as it pulls from very low revs and at no point does it feel like the turbo needs to spool up. It pulls pretty well from low revs even in higher gears. It might give the odd WRX a run for it's money if it catches one in the wrong gear or at lower revs (and if they stay at road legal speeds).
