I met up with a guy with an '02 STi. Besides being taken for a hard 'spin' and driving the car myself, we did some acceleration comparisions as well. We did a fair few runs (ie. around 10), but the location and timing was not suited to anything else but 100 - 160kph runs (and the odd 80-160kph starting in 3rd gear). Here's how things went:
- Test #1: 80 - 160kph, both cars starting in 3rd gear:
The first few times we run, I jumped on the throttle a fraction before him and jumped to a 1 car lead straight away. Though, from there on, I could not see any difference in terms of acceleration .... maybe I pulled away another 1/2 a car, but that's about it.
- Test #2: 80 - 160kph, both cars starting in 3rd gear:
Next few runs he started a fraction ahead and pulled about 1 car on me straight away. Then all the way to the top of the 3rd gear there was nothing between the cars. Once into 4th the Zed may have been a slightly quicker, but we're talking at most about a 1/4 of a car made up from 140 - 160kph.
- Test #3: 100 - 170kph, both cars starting in 3rd gear:
This time we managed to start at more or less the same time and we stayed next to each other through the 3rd gear (ie. up to 140kph). Then when I made a gear-change to 4th, I lost about 1/3 of a car-length. Then things did not look that different, but I did manage to 'creep' back the 1/3 of a car-length by 170kph. So in this run we ended up next to each other like we started ... perfectly even. Later I noticed I had my A/C on ... not sure if it made me any slower. I would not think so.
So in summary there's practically nothing between the STi and my 350Z when accelerating from 80 to 160kph. It looks like the Zed is maybe a fraction quicker at higher speeds (ie. over 150kph), but it's barely noticable. I think that the Zed may be even quicker over 180kph, but we did not go to those speeds when next to each other ... just seperately in each car. Either way, when the STi has 4000+ rpm on the tacho, it is a very good match for the 350Z.
When I get a chance/opportunity, I'll do some 'comparisions' with the car in diffrent gears and at much lower speeds. Though, I can practically quarantee that I won't be able match the STi from a stand-still start.
ps. My car has the Hi-tech exhaust and K&N filter. Also, there was only the driver in each car.
