1 - 2 of 2 Posts
I had to rebuild my engine so I went with the Cylinder Support Solution modifications to the short block etc etc.
While the engine was out we got the Nissan Pathfinder rear cooling modification for the 350Z because the engine is Greddy twin turbo and could use the extra cooling.
Now the engine is back in the car but we cannot connect the OEM coolant temperature sensor because the plug on the coolant pipe is hard against the camshaft position sensor plug.
Am I overlooking something or do we have to cut the coolant wire and put a modified plug on it?
Super Moderator
Sorry Bob- I've never done the Pathfinder coolant mod on my Z, so I can't comment. But knowing how the CPS can go out, I sure wouldn't want the plug on the coolant pipe located anywhere near it!
1 - 2 of 2 Posts
