121 - 140 of 189 Posts
Super Moderator
Discussion Starter · #121 ·
Second place again in the wet, but it's clear the Z was more fun to drive in T1 trim. As expected, the Z06 had less of an advantage on a damp track, but top end gave it a decided edge (150 vs. 130 MPH) going into the turn one passing zone. Still, the fact that the Z still finished only 20 seconds back after a 40 minute race was notable.
Super Moderator
Discussion Starter · #122 ·
Reading the most recent posts to this forum, I think the alternate title to this thread should be: "Do you like racing?" After all, this is an automotive forum dedicated to 350Z owners and the 350Z has a long and successful racing heritage. The second race of 2019 is the Rocky Mountain Division SCCA opener at LaJunta called The Ice Breaker. This is a short 1.3-mile airport circuit that takes about a minute to lap seven turns in. The opposition is yet another Corvette Z06, built by Phoenix Engineering out of Pennsylvania and driven by a veteran racer. The Z has an advantage in reliability, otherwise, the power-to-weight ratio of the Z06 will be tough to overcome!
Super Moderator
Discussion Starter · #123 ·
Update from the LaJunta SCCA races: four races with one first and three second place finishes. The Z was competitive, but the Z06 had the top end power to hold the lead on this fast and bumpy airport circuit.
I'm always lurking from the shadows, but I gotta get out and congratulate you, well done!!!, keep it up!:cheers:
Super Moderator
Discussion Starter · #125 ·
Thanks, I plan to keep racing as long as the enjoyment is there!
One other issue of note is the scaled weight at the SCCA impound last weekend. After subtracting my weight, it appears the T1 race Z is down to 2,890#. That's with a fully stripped interior, but with intact door bars and rear hatch (glass, wiper and motor), along with SCCA-compliant six point rollcage and fire system. T1 weight for a Z33 is 2,450#, which is a laugh, as there's no way to get down to that weight. Plus, I'll be reinstalling the cool suit tank as the weather gets hotter for the next few races.
Super Moderator
Discussion Starter · #126 ·
Memorial Day 2019 race weekend report from Pueblo Motorsports Park in southern Colorado. The 350Z scored two second place SCCA Majors finishes in Touring 1, but that was far from the entire story! The Z ran well on Saturday but could not match the pace of the GT1 twin-turbo Porsche 911 or the T1 Corvette GS that finished 1-2 both days. There was plenty of racing action both days, but my biggest problem came mid race on Saturday when a BMW Z4 M-coupe hit my RR wheel/tire attempting a pass. The impact threw me across the track and it took me several turns after the hit to determine whether the damage was terminal.
The Z is one tough car, so I decided it was worth the gamble to continue. I took off and began hunting down the BMW and the Porsche Boxster ahead of it. Applying pressure once I caught up, I ended up making two clean passes to finish fifth overall, but the real surprise was when we got to impound. The RR Enkei RPF-1 wheel was badly damaged, with part of the outer rim peeled back and exposing the bead of the BFG R1-S tire. If I'd known the damage was this bad, the Z would have been retired immediately! After a short talk with the BMW driver and the race stewards, he apologized and I decided not to protest his ill fated pass attempt.
Inspecting revealed more damage. the wheel-to-wheel contact had banged the wheel bearing hard, but also sent a shock wave up though the half-shaft to the NISMO diff. Continuing in the race, had allowed some of the loosened diff bolts to shift and knocked the RR ABS sensor to shift. This didn't come to light until Sunday when the ABS diagnostic system gave me a C0010 code and we figured out that the ABS system was compromised. Unfortunately, by this point, the sensor harness itself was shredded and that's not a component either myself or any of the other Z teams had in their spares. So, no ABS for the Sunday races.
In a separate issue, one of the rookie drivers who'd been racing a H Production Datsun 1200 came up with a show-stopper. His A-series engine had suffered a bent pushrod and his crew had spent the night trying to repair the damage, only to determine the damage was terminal. This driver needed a finish to qualify for a racing license and I decided to help. Although our races were back-to-back, we got him fitted to the car and changed his entry to allow him to race the Z. The driver, Ian Sullivan, is a friend of mine and he went on to do a nice job driving the car smoothly to a finish and bringing it back to the paddock to be refueled and into the next race. Starting the Sunday race, it was clear the grip and race pace was down from Saturday. My goal was to make half distance and get the finish, but never got the signal.
On lap 14, the brake monster got me, and I locked up the fronts going into T1 at about 118 MPH. My usual line takes me deep into the turn with threshold braking and the fronts locking put me in immediate danger. With so little track space to recover, I was off the lip of that banked turn in a flash. Flying through the air, all I saw was sand and BIG rocks in the runoff area! Landed with a crash and kept the steering straight to prevent any dig in and potential rollover. While I covered enough laps to be counted a finisher, that was the end of my third race weekend of the year. Loading my sand-covered Z into the trailer, lots of work to be done before the next race in July.
Super Moderator
Discussion Starter · #127 ·
Assessment of the Z revealed more damage: the stamped steel oil pan on the HR was smashed in the front and dented. Worse, the rear swaybar was bent by rocks to the point I had to pull it. Exhaust pipe from headers to muffler is twisted and bent. Plenty of other small dents, dings and other damage on the underside of the Z and lots of damage to repair- this is the reality of racing.
Super Moderator
Discussion Starter · #129 ·
Incredible experience I am sure, expensive endeavor, do you have sponsors?
In racing today, there are contingency sponsors who will provide cash or product if you win races. Nissan, BF Goodrich, Cobalt Friction and Summit Racing are among the contingency sponsors on my Z. But covering race damage is not part of the deal.
Super Moderator
Discussion Starter · #130 ·
With one week to go before the next SCCA Majors race, the news on the race prep front is concerning. The titanium mid-pipe is dented and bent- not an easy piece to repair! Even more concerning is the ABS system diagnostics are indicating a problem with the system. After gambling (and losing) with a major brake lockup at the last race, that's not a risk I want to incur again.
Looking at the current standings in the SCCA Mid-America Majors standings, my 350Z holds second place ahead of a turbo Mazdaspeed Mx-5 and Audi TT RS from the Midwest. However, a pro-built Corvette Gran Sport holds a sizable advantage and the points lead over all of us at the midway point of the season.
Super Moderator
Discussion Starter · #131 ·
Here's another update to fend off the increasing spam and meaningless posts this site has recently encountered. The T1 Z has been repaired and will be ready for the final SCCA Majors race ("Last Chance Majors") in the Mid-States Conference next week. Brakes, exhaust and other damage have all been addressed and I've got the Z just slightly under 3K pounds by my estimates (scale weights at impound). Let's light the fires and kick the tires at High Plains Raceway!.
Good to hear you got it all buttoned up and ready to roll! Refresh my memory.... you're in 2nd. In T1?!?! Holy smokes, dude, that's awesome!! Headed to VIR, are ya now? You'll get to run with all of the well heeled arrive n' drives from Phoenix Motorsports again! Hahahaha!
  • Like
Reactions: Joetor
Super Moderator
Discussion Starter · #133 ·
Weekend race report: worst to first! The Last Chance Majors was challenging on so many levels. First, ABS is still not fixed, so I locked up several times in the first race until I figured out how to drive around the problem. Brakes are usually a strength of the Z, but not this weekend. The Sunday race saw the Mustang Boss 302R (which dominated the Saturday race) take a pass and my 350Z to be the only T1 in the field. No matter, I raced as hard as I dared, and passed two ponycars ahead to finish 8th overall. With summertime temps reaching 100 degrees F (and inside temps above 120), it was a battle just to see the checkered flag, but we made it.
Series finish in the 2019 SCCA Mid-States Majors tour was second in Touring 1 with 130 points. Let's just say the 350Z did it with reliability with six points paying finishes in six races. Speed? Over-matched, by a country mile...
Super Moderator
Discussion Starter · #134 ·
Had a great time racing in the final 2019 SCCA Rocky Mountain Championship race at LaJunta this weekend. Won both T3 races when the Porsche opposition went out with a tranny failure. The Spec Boxster had just had a new clutch/flywheel/master installed, so it was unfortunate the tranny went next! I battled my own mechanical issues, as the ABS fix I installed (new steering position sensor) failed to work and I locked them up on several occasions in practice before changing my driving to brake slightly earlier and squeezing on and off, rather than going to the middle pedal more aggressively.
Had some great racing with a E Production RX-7 and A Sedan Firebird, but also had a great time coming from dead last after missing qualifying for the first race. After finding severely flat-spotted tires, one of my Nissan buddies spotted a more serious problem. The LR wheel bearing had gone and was wobbling like a top! That vibration I felt at 110 MPH was way more than just flat spotted tires in the practice session, and I was EXTREMELY fortunate it didn't result in a severe accident. Many thanks to my Nissan mates: Ian Sullivan, Nick Leone and Scott (who run a HP Datsun 1200) for jumping in and helping me get this changed out in under two hours.
We both missed qualifying and started from the back, but had a blast passing cars all around the 1.3-mile circuit. While this might sound simple, you still need to practice patience in setting up and completing clean passes without any contact, or disrupting other class races. The race weekend was disrupted by an impending Colorado winter storm bearing down on the state. Rather than racing in potentially hazardous conditions (my 350Z rain tires were ready, but the snow/ice tires were NOT on the trailer), the race officials decided to accelerate the schedule and run both RMDiv races on Saturday, while the weather held. No qualifying for the second race, and you started where you finished in the first race.
Packed up afterwards and the Titan got us home before the icy rain/snow mix coated the road. I used up several older BFG tires, which helped clear out my used tire inventory. And while my 2019 SCCA racing season didn't result in any championships (T1 Mid-America Majors and RMDiv series = 2nd place, T3 RMDiv series = 3rd), it still felt RICH in satisfaction to have competed!
Super Moderator
Discussion Starter · #135 ·
As the off-season for racing gets started, there's still some work to be done. First, this is the time to campaign for rule changes with the SCCA for 2020. Z fans may not realize it, but the 350Z has been handicapped over the past few years in Touring classes. I've asked for slightly bigger intake restrictors for the HR (40mm vs. 37mm), a lower minimum weight (3,250 pounds AFTER the race) and wider tires (275 vs. 245 cross section) for the 2020 Touring 3 class. This request will be considered over the coming months and I'll post up the results when a verdict from the rule makers is reached.
Super Moderator
Discussion Starter · #136 ·
No answers yet on the T3 competition requests, although an update stated the SCCA comp board is still studying it. I've also filed a separate request with the CRB to classify the 350Z in Super Touring Under (STU) which would allow more upgrades to aero and other areas. Hopefully, we'll hear something before the 2020 competition season opens.
Hay Guys I need a little help I'm setting up a 2009 370 as a T3 car. Following the GCR and running a 245 tire. would you use a stock 18" Nissan wheel (square setup) and is a 1/4" spacer adequate in front of the restrictor? Thanks
Super Moderator
Discussion Starter · #138 ·
Glad to hear from another Z racer! As far as setup goes, I suggest using a lighter weight 18X9" alloy wheel like the Enkei RPF-1. As for the SIR spacer, I don't have exact specs in front of me (car and trailer is in storage), but I think it was closer to 3/8" to clear the butterfly. Are you fabricating the spacer yourself?
Good luck racing the Z34, it seems more problematic to run, as the electronic controls are more complex. Which Majors conference are you racing in?
Thanks for your response. I went out today and bought after- market wheels, for the life of me I can't remember the make but they are 18x9. As for the restrictor, yes I will be cutting the aluminum to size and sending them out to a machine shop for the bore. Reading you blog, back on 7/15/16, you mentioned you used 1/4" spacer and it worked well.
I'm in the Mid-Atlantic, Steel City (Pittsburgh) chapter. Thirty years ago raced ITS class with a 78 280Z and just getting back into racing. March 2020 plans are to attend drivers school with the new car.
A few questions if you don't mind. Do you have any input on toe-in? What do you think about the 5.1 brake fluid? What gear grease do you use in the transmission? I won't be racing in 3 digit temperatures. I appreciate your time. You are the fist T3 Nissan racer I've been able to get in touch with. Thanks for your help.
Super Moderator
Discussion Starter · #140 ·
For toe, I've had success with 1/32" toe out F and the same amount tow in for the rear. As for brake fluid, a good glycol based 5.1 brake fluid will help, but they are pricey. I've used Motul RBF 600 for a few years as it has high heat resistance for a DOT 4 fluid and is readily available at a lower price. For our six-speed trannys, I use Redline MT85 as it has the right amount of friction engineered in to allow syncros to function properly. I use it for my street Z as well. Good luck with your T3 Z- perhaps we'll see you at the Road America Runoffs next fall!
