350Z SCCA racecar
41122 Views 190 Replies 15 Participants Last post by  dkmura
3
This Z was built to compete in the SCCA Touring racing classes, and has the distinction of winning in three different Touring categories: T2 (2008-2012), T3 (2013-2015) and T1 (2015). Most of the mods are concentrated in the suspension, with Koni DA shocks, Eibach springs and fully adjustable swaybars. Enkei wheels and BFGoodrich R1-S tires provide the stick, while Cobalt Friction XR2 pads provide stopping power.
For 2015, we had success in winning the Rocky Mountain Division Championship in both Touring 1 and Touring 3. Traveling to Road Atlanta, the Z has won back-to-back Touring 3 titles the past two years in the American Road Race of Champions (ARRC).
There's still plenty of SERIOUS fun to be had with the Z33!
See less See more
  • Like
Reactions: 3
61 - 80 of 191 Posts
Wow- despite posting an update on racing the Z, including graphic pics, not even one response!
That tyre looks terrible yet you were still able to race - unreal
I'm debating turning ABS off
Thanks for the reply, MartinZ. Yes, it was difficult finishing that race with such a badly flat- spotted tire, but I'm glad BFG has such robust construction!
You must be a much better driver (with a better setup) than me if you are able to race effectively without ABS. Many of my GT racecars lacked ABS, and I had a lot of success without it. But road racing a bigger and heavier car like the Z33 means ABS is critical to threshold braking.
It's more that our track cars and tyres and brake calipers/pads are able to exceed the factory expected deceleration rates which causes the ABS module to trigger when it's not actually needed.
At the same time your point is very valid, at the threshold things can become nasty resulting in big disappointments (sometimes costing a lot of money).
One set of race pads I used had wonderful bite but very little pedal feel - which puts me at risk of locking up without ABS
It's become standard operating procedure to check the ABS light before any practice, qualifying or race session. Most times, I like to get to the pre-grid well in advance and shutdown as I finish getting my window net, HANS, shoulder harnesses, etc. all set up and attached properly. I'll light the fire at the two minute mark and if that light comes on, I'll do a quick manual reset to eliminate it.
And you're right..."big disappointments" from ABS failures can range from flat spotted tires to DNFs or a totaled Z. That's about as BIG as it gets!
  • Like
Reactions: 1
I had issues the other week at the track. They did a safety inspection and cleared me, but after the first round of testing the track, I found out my battery anchor broke loose and was throwing my battery all over the compartment. Had to do a quick fix to get it safe again. Ugh...
Hmmm, 10+kg of lead loose under the bonnet, nothing good would come from that...
There are plenty of spares I carry in the race trailer, but after reading this post, it made me think. There's a extra battery tie-down strap and hardware that I rescued from the ZR parts car for storage as a race spare. Probably won't ever need it, but at least it's available NOW...
LOL glad to be of some help, David.
I knew something was wrong when I was on my cool down drive and all my dash lights started flickering. I thought I had broken the car. Luckily, we fixed it in the paddock area and I was able to go back out.
While it's still over a week away from the 2016 SCCA Runoffs, preparation on the T3 Z are nearly complete. The 40 mm air restrictors and spacers have been reinstalled, and wheels and tires remounted. But those last subjects deserve a bit more explanation: when SCCA's comp board mandated the 350Z use a max tire size of 245 (35-40) 18, to say I wasn't a fan is an understatement.
After running a BFG R1S in the June Majors and July RMDiv races, I took those tires off after a few heat cycles and stored them in the basement until this past week. Mounting them on 18 X 9.0" Enkei RPF-1 and PF-01 front wheels was the best I could do. After all, the 18 X 10.0" rears are too large for those small tires, so those get left at home for this race. That means I'll only have a total of six wheels to use for dry tires for the race.
But looking at those used 245s next to a set of much more used 275-40-18s made me realize my fears had been realized. While tire wear is always variable--with track layout, temperature and other factors in play--there's no doubt these 245 BFGs were already well-worn despite trying to hold down actual mileage. With a minimum weight of 3,300 pounds (in impound) the T3 Z really pounds those R-compound skins. They have twice as much wear after two weekends as the 275s do. I'll use these tires for the first practice/qualifying sessions at the Runoffs, but hope to buy only one new set at Mid-Ohio for the final session and race. There's little doubt the Hoosier R7 competitors who have 4-5 sets of tires will have an even more marked advantage during Runoffs week.
See less See more
I can see your pain!
My Jenvey ITB's are something like 51mm so the 40mm restrictors would hurt for sure
While money would solve the tyre wear problem (having a decent supply of tyres to consume) it would still leave you with less grip
The original intent of the SCCA tire change was to slow the Z down, but that can be overcome with enough money for fresh tires. My problem (besides not wanting to spend money) is the tires I get usually last several races, but longevity will NOT be part of this package. Rule changes meant to equalize cars usually end up costing competitors in many different ways....
Indeed, I do the same thing, buy used tyres that are in good condition, saves numerous hundreds of dollars
Here's an interesting fact for the '16 Runoffs. Out of the 500+ cars entered, there's only five drivers in 350Zs, myself included. There's another three S30 (240-280Z) Z cars entered in the Production classes, but that's about it. Nissan remains the most winning marque in Runoffs history with 99 National victories over the years. Let's get that 100th win next weekend!
After completing the 1,344 mile trip back home, I can post a bit more on the 2016 Runoffs. First of all, congratulations to Derek Kulach on his stellar drive to his first Runoffs victory and to Nissan for scoring its 100th Runoffs win- most of any marque in SCCA history! That Derek's Z33 managed to win over past champ Chad Gilsinger and his semi-works Acura TL at his home track makes it even sweeter.
My own race was a struggle. At the start, I avoided making any dumb mistakes by going too far off line on a slick track. Since we were the first race out that morning, the early laps were tricky as the field strung out. The setup I prefer on the Z is with just a bit of oversteer dialed in and I hoped the car would be faster as the race wore on. Unfortunately, my lap times stalled in the 1:41s and never dropped from there. That lack of speed meant I couldn’t challenge the BMW and Z car just ahead, as they slowly pulled away.
As stated earlier in this thread, Mid-Ohio doesn’t tolerate pushing too hard and I nearly spun several times in an attempt to shave just a bit of time off in different corners. Pushing the envelope continuously also put me further behind as the race went the full 23 laps with no caution periods. It didn’t help that the ¾ tank of race fuel I started with began running out over the final five laps. Another miscalculation that would seal a DFL finish. One bright spot came when I pulled over on the last lap to allow Derek through and cover his six as we ran under the checkered flag. It was an honor to share his celebration on the cool down lap- two Nissans running side-by-side down the backstraight and waving at each other and the corner station crews!
Still, this was a sobering Runoffs as it’s clear my vision, reaction time and overall driving have deteriorated enough to drop me from the top rank of drivers. This race had a good group of talented Runoff rookies (Like Derek and Lans Stout, who finished third is his Z33) and four former National Champs to contend with. Usually, I hold my own with such company, but not this year. Still, the lure of driving in competition and being part of the short-lived, but intense community in the Nissan tent makes it difficult to give up. I’m not sure what the 2017 season will hold for me, but as far as a finishing position, there’s only one way to go!
See less See more
Hail to the victor! Following Derek Kulach's NISMO 350Z through to the checkered flag at the 2016 SCCA Runoffs:
See less See more
Nice professional race report on the T3 Runoffs race:
https://www.scca.com/videos/2029816
350Z owners take note: the Z33 scored Nissan's 100th Runoffs victory! With multiple victories in SCCA competition it's proven a worthy link in the legendary Z racing heritage. And YOU can still be part of it if you learn to race or rally your Z at organized events around the country.
2017 SCCA Runoffs update- The 350Z has won yet another National Championship at the Indianapolis Motor Speedway. Derek Kulach has taken back-to-back Touring 3 title against opposition from BMW, Ford, Mazda and Porsche. His luck was better than T3 polesitter Rob Hines, who was taken off track in a battle with a Porsche driver. He fought back to finish fifth in his 350Z after falling to the back of the pack.
The 350Z remains a potent force in door-to-door racing!
