1 - 3 of 3 Posts
Hello all,
I am looking at purchasing a 350z however the model I am looking at is the base model. My question is, If I take out the open diff and put a stock viscous LSD unit into the car, will this directly bolt in? The 350z is manual.
Any help would be greatly appreciated! ( also quick help would be awesome as the auction for this car is this weekend)
If you are replacing the entire differential assembly (pumpkin) with both axle shafts then yes, it will bold right in. If you are swapping just the LSD gear inside the differential assembly then you will probably need axle shafts from a differential that was a VLSD.
I did this on my car now 2 times. Went from Open to VLSD I got off ebay then to another 1.5 way LSD. Cost me about $75 at my local shop for them to swap them out.
1 - 3 of 3 Posts
