Welcome- there could be several reasons why your Z won't start. The problem is there's too many possibilities and we need more facts to start narrowing them down. How long have you owned this Z? How many miles are on it? Did it do this from the start, or when did this problem first occur? Have you pulled any codes from the onboard OBD2 diagnostic system?
i bought this Z almost 3 weeks ago with a rebuilt engine. Owner says 88k on engine . And it started on Christmas Eve after I drove it 1 time that day. It had a one click crank start . And the engine sounded weak when it started. For safe measures I replaced the starter with a used starter that worked. I jumped started the starter and it worked fine. I haven’t checked for any codesWelcome- there could be several reasons why your Z won't start. The problem is there's too many possibilities and we need more facts to start narrowing them down. How long have you owned this Z? How many miles are on it? Did it do this from the start, or when did this problem first occur? Have you pulled any codes from the onboard OBD2 diagnostic system?
