Good afternoon everyone, I hope you are well.
I have a 2004 nissan 350z enthusiast MANUAL, and I have the following problems.
  • The car has no power (it costs a lot to raise the RPM), almost impossible to drive.
  • Apparently when it is cold it has a good idle / oil pressure, when warm it starts to shake and goes down to 600rpm and turns on the oil pressure light.
  • I reset the codes and after a while on they reappear.
p0011 and p0021.
I have tried the following:
  • Change all timing chains and their tensioners.
  • Change VVTs.
  • Change the oil and its filter.
  • Change the oil gasket.
  • Change the battery.
  • Change the injectors.
I'm really asking for your help, I don't know what to do anymore.
Got a video if you need it.
Super Moderator
Sounds like you're in limp mode. How many miles are on your Z? Have you tried replacing the camshaft position sensor?
Super Moderator
You've done a lot of replacing, but it's time to bring in a pro wrench with a CONSULT 3 to do a diagnostic.
