1 - 20 of 101 Posts
ok, looking to ride in a Z w/ 3.9 in the rear.
This will most likely be my next mod along with getting the rest of the ARC parts. (intake and stb)
Hoping to find someone around the area.. or if nothing else, find out more about it.
Is anyone getting this done any place besides 350evo.com in Cincinnati?
**** yeah.. ill buy one.. maybe we should look into doing a group buy
I'd be interested in a group buy.
Discussion Starter · #17 ·
So parts needed would be...
Pinion gear & ring gear $850
Side Bearing x2 $85
Side Bearing Oil Seal x2 $12
Drain Plug Washer x2 $3.90
Final Drive Gear Bolt x10 $20
Final Drive Side Gear Cir-clip x2 $1.40
Pinion Shaft Oil Seal $8.95
Pinion Shaft Crush Sleave $9.50
Pinion Nut $5
Front Pinion Bearing $34.95 (Item & price from 350evo's site)
Rear Pinion Bearing $54.95 (Item & price from 350evo's site)
Let alone all the shims.. Pretty much order all available shim types.. and then return the ones you don't need.
1 - 20 of 101 Posts
