1 - 3 of 3 Posts
Hey guys, I have the trunk completely apart, there seems to be some wires against the trunk rear middle or, checking the service manual there seems to be a harness around the jack area. Does anyone know which and where the wire is located? The service manual is really non-descriptive, and the wiki links do not seem to be working from other threads.
-zip-,
For harness routing, see the pg.pdf section of the Service Manual. You want the Tail Harness. In the 2008 manual it's on page PG-57.
The lt.pdf section shows wiring with color codes. At the light connector the back-up light wire is light green.
Discussion Starter #3 (Edited)
Thanks Karl, really apprecaite the help with this, its going to save me hours trying to find it through a tester.
I have a 2007 manual, would like a 2008 but the wiki is broken. If anyone has it, please PM me, and I will ping my email addy. Thanks so much for your help.
For now I will use the 2007 manual which will probably be the same.
1 - 3 of 3 Posts
