Been a while since I've been on here. Wasn't happy with the results NA, so decided to boost it a couple years ago. Here she is:
2007 Nissan 350Z VQ35HR, somewhere around 650 whp at 15psi ( last dyno was at 13psi and it put down 620 at the wheels ).
ENGINE:
GTM Stage-3 TT kit, GT3071R turbos
3.8 liter stroker crank, polished crank
GTM spec rods, Arias pistons
Balanced and blue-printed
Ported and polished heads and lower intake plenum
GTM Stage-5 return fuel system, twin Walbro 255lph pumps, billet filter/fuel rails, Bosch 900cc injectors
AEM FP regulator
HKS plugs
GTM Stage-1 valvetrain upgrade, dual springs, titanium retainers and keepers
GTM performance MAF's
GTM main, rod, and thrust bearings
GTM 3" downpipes
Tial wastegates and blowoff valves
Greddy Turbo Ti-C modified with 3" inlets
Tuned with Osiris UpRev
Tomei cams, 264 in and out
ARP head and main studs
ARC oil filler cap and radiator cap
AAM oil pan spacer
Setrab oil cooler
Cusco oil catch can
Koyo radiator
Samco hoses
DRIVETRAIN:
OS Giken twin plate clutch and flywheel
ATS and Across Carbonetic LSD
Heavy duty CSC upgrade
AAM SS clutch line
NISMO cooling fin diff cover
Whiteline rear subframe bushing/traction kit
Whiteline rear diff kit
WHEELS/TIRES/BRAKES:
Mag Blue Volk Racing CE28N 19x9.5 +12 and 19x10.5 +12
Advan Neova AD08 255/35/19 and 295/30/19
Endless Racing R6/R4 BBK
Project Kics R40 lug nuts
SUSPENSION/CHASSIS:
Tein Type Flex coilovers with EDFC
Tein tie rods and tie rod ends
SPL end links front and rear
Cusco 6 point roll cage
Cusco adjustable front upper control arms
Cusco adjustable sway bars
Cusco front strut tower bar
EXTERIOR:
Voltex side skirts
Voltex rear diffuser and underpanel
Voltex Type-II 1500mm wing
Chargespeed front bumper with CF canards
Craftsquare CF mirrors
Seibon CF TS-II hood
Aerocatch flush mount hood pins
LighterFaster bumper diffusers
Benen Ind tow hook ( rear )
Z-speed performance underpanel
Wiper delete front and rear
Painted door handles and emblems
INTERIOR:
Takata Race LE seats
Planted Tech seat bases
Takata Drift II harnesses
Works Bell Rapfix II quick release and hub adaptor
Key!s Racing 330mm suede steering wheel
Key!s Racing suede shift knob
Defi Advance CR 52mm, boost, water temp, oil temp, oil pressure gauges w/ control box
ATI steering column gauge pod
HKS A/F-Knock amp
HKS EVC-VI boost controller
Enjuku K-bar harness bar
NISMO floor mats
NISMO pedals
Pioneer head unit
Alpine speakers ( stock locations )
JL amp
ENGINE:
AEM FP regulator
HKS plugs
GTM 3" downpipes
AAM oil pan spacer
Setrab oil cooler
Cusco oil catch can
Koyo radiator
Samco hoses
DRIVETRAIN:
AAM SS clutch line
SUSPENSION/CHASSIS:
EXTERIOR:
Voltex side skirts
INTERIOR:
HKS A/F-Knock amp
NISMO floor mats
NISMO pedals
Pioneer head unit
JL amp
