I bought these last night.
Pretty sure it is a mistake. I asked from every direction and he verified part number and application.
DBA 09+ 370Z Sport G37 Sport Front Drilled & Slotted Rotors Pair 52314BLKXS | eBay
DBA 09+ Nissan 370Z Sport / Infiniti G37 Sport Front Drilled & Slotted 5000 Series 2 Piece Rotor Assembled w/ Black Hat
DBA 5000 Series Rotors are a high-series enhanced performance rotors. These rotors feature Thermal Stability Profiling for improved heat handling, Thermo-Graphic paint markings for effective heat monitoring and Kangaroo Paw ventilation which runs cooler, stronger and outperforms traditional straight vane disc rotors by up to 20%.
The aircraft-grade aluminum center/hat provides greater resistance to distortion as it allows the disc to expand uniformly.
The DBA 5000 Series Brake Rotors are designed for the serious driver. These 2-piece ultra-high performance rotors feature aerospace grade materials for added thermal (heat) protection to you vehicle's wheel bearings.
*Slotted*
The slotted pattern provides an effective means of dispersing debris and gases while maintaining consistent friction and a cleaner disc rotor.
*XS*
The premium cross-drill and slot pattern provides an efficient means of dispersing debris and gases while maintaining consistent friction and a cleaner disc rotor.
Part Number: 52314BLKXS
Notes: 5000 Series Rotor; Drilled/Slotted Rotor
Manufacturer: DBA
Color: Black
Position: Front Pair
