1 - 2 of 2 Posts
Just purchased a 06 roadster and the steering wheel audio conrols are in op. The car just has the base factory unit single disc etc., not the bose. Anyone out there every had this problem or have any ideas. Also I think at one time a previous owner may have had a sub woofer in it due to seeing the factory cover in that area loose and wires behind it, which means most likely had a aftermarket unit in and out. Any ideas or input would be very helpful.
This is old but saw no replies if its all stock then the steering wheeling control plug is not plugged into the radio. If it is plugged in then its more then likely the steering wheel controls. This is a common thing I see at my audio shop when people buy cars
1 - 2 of 2 Posts
