Does anyone know of any 05 F/I Z's out there I am getting ready to go F/I just want to see if anyone has done it yet on the 05's I know the ECU's are different and wanna see if they had any bugs or hicups along the way....
Thanks..
Thanks..
Originally posted by Nis350ZTT@Jun 14 2005, 01:20 AM
And actually, it's just a myth, any 350Z's made around August 2004 and on have the same ECU, which uses wideband O2 sensors. Some are 2004, some are 2005. (the 2004's are often called 2004.5)
[snapback]113778[/snapback]
Originally posted by Nis350ZTT@Jun 13 2005, 09:20 PM
There are a few up and running. APS has tested their's on 05's and haven't had any problems. Same with GReddy.
It should work fine though, the timing to retard and some other things will most likely be different than they are for 350Z's made before Aug. 2004.
Originally posted by daveyello+Aug 15 2005, 03:28 AM--><!--QuoteBegin-Nis350ZTT@Jun 13 2005, 09:20 PM
I have a late model 2004 and installed the APS TT. I was getting Bank 1 O2 senosor codes. Is the wideband sensors more sensitive than the earlier (pre-2004) models? I put test pipes on and now the codes are gone. Could some one clear this up? Peter from APS says nothing changed in terms of the ECU's.
[snapback]145601[/snapback]
