I have a 2005 35th special edition 350z, im looking to lower it but wanted to put some wheel spacers on but wasnt for sure what thickness I should go with. Does the front and rear wheels stick in the same amount or no? I do not want to get spacers and the front stick out and the rears dont. Any help would be appreciated!
Discussion Starter #2
Wheel spacers
I have a 05 350z 35th special edition so i have the brembo brakes and the 18inch alloy rims. I want to lower my car and also put wheel spacers on but im not for sure what size would look good. My question is; do the front and rear tires sit in the same ? I do not want to buy 1 inch spacers all the way around and my front sit out more than rear.
This really depends on the offset of the wheels you choose. Some will require a spacer just to clear a Brembo caliper in the front, while others will not. Keep in mind that you may need longer wheel studs to safely use a spacer, and that spacers inherently put more axial load on the wheel bearings over time.
