Holy pizza platters, Batman! - Page 4 - Nissan 350Z Forum, Nissan 370Z Tech Forums
post #31 of 36 (permalink) Old 03-26-2006, 07:34 PM Thread Starter
Can you please let me know if you had to grind/cut anything (Dust shield) when you installed the front brakes? Also, what type of pads are you using? Also, any noise when braking?
Thanks Looks great!!
Yes, I had to trim the dust shields. For the front, the instructions called for only a small section around the caliper bracket, but I ended up cutting the whole thing off. For the rear, you have to cut off the whole shield. Note, it's the dust shield and NOT the thicker shield that acts as a wall for the emergency brake shoes. Also note that I got the ST-22 calipers for the rear and not the ST-45's. The ST-45's require more shaving and cutting as the caliper brackets are very different than the ST-22's.
Here's a shot of the rears.....
[attachmentid=13879]
Conan is offline
post #32 of 36 (permalink) Old 03-26-2006, 07:46 PM
Ronin Z's Avatar
Quoted: 4 Post(s)
Glad to hear you got it all sorted out. Nothing worse than installing a much anticipated mod and have it turn south on you. You are now a member of the rarified BBK Club*. Congratulations!
Best Regards,
Ronin Z
*Technically those vehicles fitted with the factory Brembo braking system (like myself) are also members of the BBK Club. But since the general public only finds OEM parts 14% as sexy as aftermarket, we only get a Junior Membership.
"If you want me to treat your ideas with more respect, get some better ideas." -John Scalzi
Vi veri universum vivus vici
Ronin Z is offline
post #33 of 36 (permalink) Old 03-26-2006, 07:52 PM Thread Starter
Best Regards,
Ronin Z
Thanks! Yes, I feel a bit better now. Still need to double check and make sure the system isn't leaking at all, but so far everything seems good.
Good one. Yes, I think people forget that the track model brakes are actually the equvilent of a BBK. You could even throw slotted rotors on as easily as changing the tires.
Conan is offline
post #34 of 36 (permalink) Old 03-26-2006, 08:53 PM
Someday, I will belong to this elusive club.
post #35 of 36 (permalink) Old 03-27-2006, 08:35 AM
illz33's Avatar
Some of the BBK club is more elusive than others.
___TUNING CONCEPT, JAPAN PREMIER
illz33 is offline
post #36 of 36 (permalink) Old 03-27-2006, 04:36 PM Thread Starter
Ok, I doubt anyone other than myself cares, but since I mentioned weights in earlier posts for this thread.....
I'm a total numbers and data geek, so I weighed a major piece of the front and back on the old brake system and compared it to weights of the corresponding items of the new system during the install process using a good postal scale rated to 30 lbs. For what it's worth....
<table>
<tr><td>Part</td><td>Weight, OEM (lbs)</td><td>Weight, StopTech (lbs)</td></tr>
<tr><td>-------------------------</td><td>----------------</td><td>-------------------</td></tr>
<tr><td>Front Rotor</td><td>16.2</td><td>18.2</td></tr>
<tr><td>Rear Rotor</td><td>11.9</td><td>15.3</td></tr>
<tr><td>Front Caliper</td><td>7.0</td><td>8.1</td></tr>
<tr><td>Rear Caliper</td><td>3.6</td><td>5.2</td></tr>
<tr><td>Front Caliper Bracket</td><td>3.4</td><td>1.5</td></tr>
<tr><td>Rear Caliper Bracket</td><td>1.7</td><td>0.6</td></tr>
<tr><td>Totals (per wheel)</td><td>43.8</td><td>48.9</td></tr>
</table>
</p>
Conan is offline
