Hello,
I tried looking for someone who has had a similar problem but couldn't find anything. If someone out there has had this issue or has some knowledge on it, you would be a lifesaver. It all started the other day when I was driving in the rain and my car lost traction for a second and the vdc kicked in and it misfired. it was having a hard time keeping up the rpms and I parked immediately then it stalled. It would not turn back on so I checked for a code with my obd and it was pulling up the knock sensor error code. So I replaced the knock sensor and the wireharness, reset the codes and it still wont start. it'll try to turn, but it wont. I am assuming this is not the knock sensor and it is something else. Anything information will help! Thank you!
Info on my 2003 350z:
60k miles
completely stock except for coilovers.
Edit: I forgot to mention that the car was having a hard time turning on than usual for two days before this incident. It would take a second longer to start.
60k miles
