6 Ways you may be WASTING GAS. - Nissan 350Z Forum, Nissan 370Z Tech Forums
 1Likes
post #1 of 25 (permalink) Old 06-08-2008, 06:52 PM Thread Starter
jetpilot718's Avatar
Send a message via AIM to jetpilot718
Numbers 3 and 4, I plead guilty to. I seem to get best fuel economy (28mpg) at 75mph, and less at 60 or 80 (around 24mpg). I think maybe number 3 doesn't apply to us, since our cars are so aerodynamic. And number 4, I always thought drafting saves fuel? hehe
1. Racing away from green lights
When the light turns green, you don't have to take off as quickly as possible. That pedal under your right foot is called the "gas pedal" for a good reason. The more you press down on it, the more gas you're pumping into the engine.
Press lightly on the gas pedal, and you'll still accelerate, and you'll still get where you're going. You might be surprised at how little pressure it takes to get your car up to speed in a reasonable time.
2. Racing up to red lights
When you're driving down the street, and you see a light red light or stop sign up ahead, you should lay off the gas sooner rather than later.
There's no point in keeping your foot on the gas until just before you reach the intersection. Let off the pedal sooner and give your engine a rest as you coast to the stop while braking gently. As an added benefit, your brake pads will last longer, too.
By themselves, these first two tips can improve your fuel economy around town by as much as 35 percent, according to tests conducted by automotive information Web site Edmunds.com.
3. Confusing the highway with a speedway
Even if it doesn't involve hard acceleration, speeding wastes gas. The faster you go, the more air your vehicle has to push out of the way. It's like moving your hand through water. The faster you try to move your hand, the harder the water pushes back.
In tests by Consumer Reports, driving at 75 miles per hour instead of 65 miles per hour reduced fuel economy by between 3 and 5 miles per gallon, depending on the vehicle.
4. Bumper-buzzing
Tailgating is a bad move for many reasons. First of all, it's unsafe. You reduce your ability to react if the car in front of you slows or stops. It also means you have to pay ultra-close attention to that car which reduces your ability to scan for other hazards ahead of you and to the sides.
And tailgating wastes gas. Every time the driver ahead taps his brakes, you have to slow down even more than he did. (That's because you can't react immediately so you have to slow even more because you're slowing down later.) Then you accelerate again to get back up to speed and resume your bumper-buzzing routine.
Hang back and you'll be safer - plus you'll be able to drive more smoothly and use less fuel. A good rule of thumb is to allow two seconds of space between your car and the one ahead. You can figure that out by counting off two seconds after the car in front of you passes an obvious landmark like an overpass.
5. Driving standing still
You've probably heard that it takes more gas to restart a car than to let it run. Maybe that used to be true, but it isn't anymore. With modern fuel-injection engines, it takes very little extra gas to restart a car once it's warmed up.
Idling, meanwhile, burns about a half-mile worth of gas every minute, according to the California Energy Commission. That's why hybrid cars shut down their gasoline engines whenever they stop, even for a moment.
Now you don't want to shut your engine down for every little stop in your regular, non-hybrid car - it's not designed for that - but if you're waiting for someone to run in and out of a convenience store, turn off the engine.
And don't go through the drive-through at fast food restaurants. You're already paying enough for the oil in those chicken nuggets.
Bonus tip: Don't idle your engine to let it warm up before driving. It does your engine no good and it wastes gas. Instead, start driving right away, but drive gently until the engine is warm.
6. Short hops
For really short trips, take advantage of the opportunity to get some exercise. Try walking to the store instead of driving. You can save gas and burn a few calories instead.
If you can't hoof it, save up your errands. A lot of short hops that let the engine cool down at home between trips can use twice as much gas as starting the car once and making a big sweep to all your stops, according to the U.S. Department of Energy.
Go to your farthest destination first so your engine has a chance to reach its optimal operating temperature. Then make your other stops on the way back. With the engine warmed up, the car will restart easily and run efficiently all the way home.
jetpilot718 is offline
post #2 of 25 (permalink) Old 06-08-2008, 06:55 PM
This must be the 8th item I have read on gas saving tips.
All good info I guess
chefsz is offline
post #3 of 25 (permalink) Old 06-08-2008, 11:29 PM
[cerberus]'s Avatar
Send a message via AIM to [cerberus]
I am guilty of 1 and 3. But I hate the people Who don't hurry up at the light. There are people behind you who would also like to get through the light. so get your but in gear and get through it.
Matt
Momentum Single Turbo 370whp & 360ftlbs
[cerberus] is offline
post #4 of 25 (permalink) Old 06-08-2008, 11:32 PM
i8acobra's Avatar
People that do the first 3 are the number one cause of road rage. When the light turns green, I can't stand when the guy in front of me takes a mile to get up to the speed limit. I also can't stand it when there's a red light 1/2 mile up the road and the guy in front of me starts coasting down. They then slow to a creep 10 car lengths back from the light and creep all the way up, like they're afraid to come to a complete stop. When you get someone doing both of these things, it really gets me fuming because we never actually get up to the speed limit. We get almost there, then start slowing for the next light. You know what people, some of us have somewhere we need to be. We don't have the luxury of taking all day to complete one task. This brings us to number 3. You wanna go the speed limit on the highway? That's cool. Just stay the f*ck out of the left lane. The left lane is for passing. If you're going the speed limit, you're not passing anyone.
Aaron B.
'08 Mustang GT/CS
i8acobra is offline
post #5 of 25 (permalink) Old 06-09-2008, 12:13 AM
QUOTE (Jetpilot718 @ Jun 9 2008, 06:52 AM)
*cough*slipstreaming*cough* ;-)
I have mates who've tried to drive the 130+ miles home from a race track on almost no fuel (the town it was located in didn't have high octane back then and the jerry cans were empty), who've just sat inches from the rear bar of another car to take reap the fuel-economy advantages of drafting. They had a few nudges when they got too close, but rubbin'z economizin'.
Like #3 says about "the more air your vehicle has to push out of the way" (which isn't technically accurate as the amount of air remains the same, just the rate at which you want to travel through it changes..its not like the atmosphere drops pressure if you slow down or we'd all suffocate in a vacuum if everyone just stopped moving) there's two ways you can get around wind resistance. One is to slow down, which is their idea. The other is to get someone else to break its resistance for you :P
scathing is offline
post #6 of 25 (permalink) Old 06-09-2008, 12:29 AM
good read. when my first started teaching me how to drive some 2 odd years ago. he always tought me to cruize when you see a yellow or red light or stop sign.
Also if you want to save others gas. put your turn signal on before you brake to make a turn so the car behind you. say your on a 4 lane road will have time to get over into the other lane and not have to adjust there speed.
<span style="color:#000000">You take the children... But you leave me my monkey..
fallen612 is offline
post #7 of 25 (permalink) Old 06-09-2008, 01:43 AM
jinxxycat's Avatar
Send a message via AIM to jinxxycat Send a message via Yahoo to jinxxycat
I suppose that I'm guilty of #3 I do find myself speeding in the Z. On the others, I guess I've learned one way or another that you need to drive conservatively on public roads and leave the speed for the track. And I have to say that I am the kind of driver that leaves a *huge* cushion between myself and the car ahead of me b/c you never know what the asshole is going to pull. And as soon as I have the nice comfortable cushion between me and the vehicle in front of me, some jag off comes and pulls in front of me into said cushion....idiots.
QUOTE (i8acobra @ Jun 8 2008, 09:32 PM)
And if I come up on the said offender, I blast this song and wait patiently for them to get the hell out of MY WAY.... I don't tailgate them but I've been known to give the "friendly" flash of the highbeams (or rapidly flash them, either way sometimes they get the picture sometimes they don't)
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/shgw8m0aR4s&hl=en"></param><embed src="http://www.youtube.com/v/shgw8m0aR4s&hl=en" type="application/x-shockwave-flash" width="425" height="344"></embed></object>
jinxxycat is offline
post #8 of 25 (permalink) Old 06-09-2008, 02:16 AM
Bacon's Avatar
i do coast really slow up to yellow lights and such but its not really to save gas i will drop to like 20 or 25 and slow all the way down to around 15 to avoid stopping just to save time. If you hurry up to it your gonna have to stop and then start so it takes longer if you can level your speed before you get there to be going as fast as possible when it turns green you get to start out going like 20 not at a dead stop, you also don&#39;t have to start your car moving which takes alot of gas and you don&#39;t have to put any wear on your breaks because you can just coast to that slow. AND your saving time
Bacon is offline
post #9 of 25 (permalink) Old 06-09-2008, 03:49 AM Thread Starter
QUOTE (jinxxycat @ Jun 8 2008, 10:43 PM)
I don&#39;t tailgate them but I&#39;ve been known to give the "friendly" flash of the highbeams (or rapidly flash them, either way sometimes they get the picture sometimes they don&#39;t)
Americans have no idea what high beams mean. Or, they think it means "F*ck your mother" and they brake-check you. The only time I tailgate is when some slug is hogging the left lane and theres like 4 miles of open road ahead of them. They usually get the idea. Or, I&#39;ll just start honking like you would if someone fell asleep at the light lol
Something they forgot to mention:
Coasting to a stop in neutral is WRONG. You are using fuel to keep your car at idle speed. Coasting to a stop in gear is using zero fuel, as the injectors shut off when the throttle is closed while in gear. So your best bet is leaving it in 4th or so until you come to around 5mph, then go to neutral.
post #10 of 25 (permalink) Old 06-09-2008, 05:11 AM
QUOTE (Jetpilot718 @ Jun 8 2008, 03:52 PM)
Numbers 3 and 4, I plead guilty to. I seem to get best fuel economy (28mpg) at 75mph, and less at 60 or 80 (around 24mpg). I think maybe number 3 doesn&#39;t apply to us, since our cars are so aerodynamic. And number 4, I always thought drafting saves fuel? hehe
When the light turns green, you don&#39;t have to take off as quickly as possible. That pedal under your right foot is called the "gas pedal" for a good reason. The more you press down on it, the more gas you&#39;re pumping into the engine.
Press lightly on the gas pedal, and you&#39;ll still accelerate, and you&#39;ll still get where you&#39;re going. You might be surprised at how little pressure it takes to get your car up to speed in a reasonable time
When you&#39;re driving down the street, and you see a light red light or stop sign up ahead, you should lay off the gas sooner rather than later.
There&#39;s no point in keeping your foot on the gas until just before you reach the intersection. Let off the pedal sooner and give your engine a rest as you coast to the stop while braking gently. As an added benefit, your brake pads will last longer, too.
Even if it doesn&#39;t involve hard acceleration, speeding wastes gas. The faster you go, the more air your vehicle has to push out of the way. It&#39;s like moving your hand through water. The faster you try to move your hand, the harder the water pushes back.
4. Bumper-buzzing
Tailgating is a bad move for many reasons. First of all, it&#39;s unsafe. You reduce your ability to react if the car in front of you slows or stops. It also means you have to pay ultra-close attention to that car which reduces your ability to scan for other hazards ahead of you and to the sides.
And tailgating wastes gas. Every time the driver ahead taps his brakes, you have to slow down even more than he did. (That&#39;s because you can&#39;t react immediately so you have to slow even more because you&#39;re slowing down later.) Then you accelerate again to get back up to speed and resume your bumper-buzzing routine.
Hang back and you&#39;ll be safer - plus you&#39;ll be able to drive more smoothly and use less fuel. A good rule of thumb is to allow two seconds of space between your car and the one ahead. You can figure that out by counting off two seconds after the car in front of you passes an obvious landmark like an overpass.
You&#39;ve probably heard that it takes more gas to restart a car than to let it run. Maybe that used to be true, but it isn&#39;t anymore. With modern fuel-injection engines, it takes very little extra gas to restart a car once it&#39;s warmed up.
Idling, meanwhile, burns about a half-mile worth of gas every minute, according to the California Energy Commission. That&#39;s why hybrid cars shut down their gasoline engines whenever they stop, even for a moment.
Now you don&#39;t want to shut your engine down for every little stop in your regular, non-hybrid car - it&#39;s not designed for that - but if you&#39;re waiting for someone to run in and out of a convenience store, turn off the engine.
And don&#39;t go through the drive-through at fast food restaurants. You&#39;re already paying enough for the oil in those chicken nuggets.
Bonus tip: Don&#39;t idle your engine to let it warm up before driving. It does your engine no good and it wastes gas. Instead, start driving right away, but drive gently until the engine is warm.
6. Short hops
If you can&#39;t hoof it, save up your errands. A lot of short hops that let the engine cool down at home between trips can use twice as much gas as starting the car once and making a big sweep to all your stops, according to the U.S. Department of Energy.
Is spinning cookies anywhere on here???
You can&#39;t win. Because...
Your good...But I&#39;m Better.
z'sowntheroad is offline
