2006 Door panel removal - Nissan 350Z Forum : 350Z / 370Z Tech Forums
Old 03-22-2007, 03:41 PM   #1 (permalink)
Send a message via AIM to dmroberson Send a message via Yahoo to dmroberson
I'm trying to remove the driver's side door panel, so I can install a window rollup module, so I can roll the windows up, from the factory keyfob. I've looked at the 2006 Service Manual, however, it doesn't seem to match up.
For example, it says there's a cap inside the door handle (inside the car) and a screw is underneath. On the door, there is no cap. Seems like the whole thing is one solid piece.
Can anybody help me get the door panel off? I don't know where else to look for information, since the manual doesn't help.
Thanks.
Understeer -- n. [uhn-dur-steer] "Why isn't this $h1t turning!?"
Oversteer -- n. [oh-vur-steer] "Oh, $h1t!!"
dmroberson is offline   Reply With Quote
Old 03-22-2007, 04:03 PM   #2 (permalink)
Ronin Z's Avatar
Thanks.
The factory manual is incorrect (as they did not update it to the '06 style door). From what I remember, there is no screw that hold in the driver's side window/lock switch plate. It just clips into place. Pry it up with a cloth wrapped screwdriver. Underneath there, there are 2 bolts. The rest of the screw/blots are where the manual says.
Good Luck
Ronin Z
"If you want me to treat your ideas with more respect, get some better ideas." -John Scalzi
Vi veri universum vivus vici
Ronin Z is offline   Reply With Quote
Old 03-22-2007, 04:09 PM   #3 (permalink)
Thanks. I'll give that a try this weekend.
