Power locks, windows, and hatch button do not work - Nissan 350Z Forum, Nissan 370Z Tech Forums
post #1 of 3 (permalink) Old 05-15-2016, 03:20 PM Thread Starter
Hi all.
I recently installed a double-din stereo into my Z. I only had to use two of the three original connectors that were with the stock Bose unit (not sure if this could be related, but there is no place to plug that in at). I also pulled apart the door panels, and disconnected both door harnesses. I reinstalled everything, have since rechecked all connections, including the master switch and passenger controls, but still do not have door or hatch controls. My windows are currently stuck down. I tried the BCM reset procedure but with no luck. Ive also checked all fuses and they all appear to be in working order, (including the fuse locations under the hood). Im really unsure of what I could also check out.. Any help is greatly appreciated.
sixx23 is offline
post #2 of 3 (permalink) Old 05-15-2016, 03:38 PM Thread Starter
It may also be worth noting that my doors lock, unlock, and my hatch will open by keyfob. Windows will not roll up with key trick.
sixx23 is offline
post #3 of 3 (permalink) Old 05-16-2016, 10:04 AM
Quoted: 47 Post(s)
Hate to say it (again), but this problem really requires a Nissan tech with a CONSULT III unit to diagnose this sort of electrical fault. You clearly disconnected a vital circuit, but which one is the question. Pulling any BCM codes will be the place to start.
