Harness bar or roll cage??? - Nissan 350Z Forum, Nissan 370Z Tech Forums
post #1 of 15 (permalink) Old 03-06-2011, 06:13 PM Thread Starter
So I just picked up a set of Spaco Torino's - impluse buy, and now I have to make a decision on a way to set up the harness bar.
What is everybody's thoughts on this? Should I go with the Sparco Harness bar? A half cage?
It is my daily driver for now but that should change shortly and although I have never taken her to the track, it is something I intend to start doing as I build the suspension.
thanks for the help
1) 89' S13
2) 91' Z32 2+2
3) 03' Z33 - Touring - 666 speed.
Third times a charm.
- BLITZ Nur-Spec Touring Exhaust - Berk HFCs - VIS CF Hood - Motordyne Copper Plenum Spacer - Sparco Torino - Rays Track Wheels - RALCO Short Shifter -
VTheory is offline
post #2 of 15 (permalink) Old 03-06-2011, 06:21 PM
willy's Avatar
I would go with... a half cage. The bars sit behind the seat so that you're not in much danger of bashing your skull in. But, it SHOULD also give you some protection in case of a rollover, whereas the harness bar is more of a death trap.
willy is offline
post #3 of 15 (permalink) Old 03-06-2011, 10:50 PM Thread Starter
Thanks Willy.
I was thinking cage too.
Any ideas on which cage to choose? or where to buy?
1) 89' S13
2) 91' Z32 2+2
VTheory is offline
post #4 of 15 (permalink) Old 03-07-2011, 03:07 AM
tanabe350z's Avatar
Since the half cage goes behind the seat and seat rails, you'll not be able to move the seat all the way back. The seat belt harness bar will also shorten how far back you can recline. IF your a big guy like me, your gonna have to do some custom work..
tanabe350z is offline
post #5 of 15 (permalink) Old 03-07-2011, 10:54 AM Thread Starter
Oh, thats no good.
I drive with the seat all the way back as it is.
If I do a custom cage is there a way to mack sure I meet with standards?
I'd like it to be a legit cage for when I take it to the track.
thanks guys.
1) 89' S13
2) 91' Z32 2+2
VTheory is offline
post #6 of 15 (permalink) Old 03-07-2011, 06:55 PM
willy's Avatar
Originally Posted by VTheory View Post
Oh, thats no good.
thanks guys.
That usually will require more than just a half cage, which then puts your head in big time danger in case of an accident. ...that's why its pretty hard to find a compromise between a DD and a full time track car...
willy is offline
post #7 of 15 (permalink) Old 03-08-2011, 01:13 AM
tanabe350z's Avatar
I had an idea about cutting out a hole by the glove box and another one on the opposite side. The pipe will be welded behind glove box door area, letting you sldiethe seat all the way back. Seat belt harness bar would still be in front of the sound bar. I'd say you'll loose one to two clicks on your recline position. The only way to move back the seat belt bar, would be to remove the sound bar.
Roll Bar bellow is by Autopower Industries. I would only recommend this for show, but it will help none the less.
If you could get the small legs to mount on the sound bar and the 2 longer pipes down to the trunk, this would be ideal for big/tall people. This is considered a "roll bar" I would strongly recommend not to use the seat belt harness bar with this setup. Recommended height for harness bar is below shoulder level. If bar is above the shoulder's, the seat belt will not pull down the driver/passenger into the seat and he/she can be ejected sideways out the seat in a roll over.
post #8 of 15 (permalink) Old 03-08-2011, 02:23 AM Thread Starter
this is a hard decision.
I want to be able to run the harness and the torinos but i don't want to be uncomfortable every time a drive it! Any other ways to mount a harness?
1) 89' S13
2) 91' Z32 2+2
VTheory is offline
post #9 of 15 (permalink) Old 03-08-2011, 10:14 AM
NoZYet's Avatar
Read the installation guide, and follow them to the letter. Improperly installed harnesses can load your spine in a dangerous way. Make sure your seats are compatible with the harness you're using.
Willy's absolutely right, in my opinion track cars and road cars should be distinct entities, the safety requirements are very, very different. A half cage might be an OK compromise to get started. It might not be a bad idea to start with the cage spec in the SCCA rules book, as their requirements are the results of real (and legally responsible) engineering time.
~Pat
2010 True Red Miata Sport
From now on we live in a world where man has walked on the Moon. It's not a miracle; we just decided to go. - Tom Hanks, Apollo 13.
NoZYet is offline
post #10 of 15 (permalink) Old 03-08-2011, 11:12 AM
willy's Avatar
~Pat
The one pictured will not be legal. Get something welded in, if that's the way you want to go. I would personally avoid harnesses on the road, they're arguably more dangerous without a cage, and they're just a hassel.
willy is offline
