AAM Fuel Return System! - Nissan 350Z Forum, Nissan 370Z Tech Forums
post #1 of 4 (permalink) Old 10-04-2006, 04:49 PM Thread Starter
FIRST TIME EVER – AAM Spec. Fuel Rail Return System Sale!!!
On our constant quest to redefine the wheel we are preparing to release a new AAM Spec Fuel Rail System which is a culmination of several refinements to our classic Fuel Rail Return System. So what are we going to do with the tested, tried, and true classic Fuel Rail Systems we have in stock? We’ll we couldn’t think of a better way to end such a successful production run than to offer the LARGEST DISCOUNT EVER! This price is final and when we are out of stock – that’s it for the popular classic version!
$999.00 - $250.00 INSTANT REBATE = $749.00
As a special added bonus, we will also be including a randomly selected raffle certificate in each box which will range from $25.00 to $100.00 gift certificate for future AAM Spec. orders!
Here is the run down on what the AAM Spec. Fuel Rail Return System is:
Twin Turbos on a 350Z? Forced Induction on the VQ? Supercharged G35? Well get the fuel setup that makes it all work properly with the AAM Return Fuel Rail Solution for the 350Z and G35!
The AAM Return Fuel Rail System for the Nissan 350Z and Infiniti G35 is a direct bolt-on kit that converts the current factory “return less” fuel system to a full return fuel system. The “return less” system in the 350Z & G35 offers minimal adjustment to the amount of fuel the engine can receive. This type of system is cheaper for the factory to manufacture and works okay in a factory naturally aspirated setup, but has several draw backs when you go to forced induction.
One negative aspect of the factory returnless system is that the factory fuel pressure regulator is installed in the fuel tank. The factory fuel pressure regulator does not allow fuel pressure adjustments and is incapable of holding a constant fuel pressure with most aftermarket fuel pumps. The factory fuel pressure regulator also is unable to add fuel pressure under boost. This system is a must have for any forced induction supercharged or turbocharged vehicle and any big shot nitrous vehicles because the AAM Spec system removes the factory regulator's control of fuel pressure and replaces the control with a vacuum/boost sensitive adjustable fuel pressure regulator. This allows you to adjust both the level of base fuel pressure and increase fuel pressure under boost.
BENEFITS:
•Adjustable base fuel pressure (35psi to 65psi)
•Increases fuel pressure under boost (about one pound of fuel pressure for each pound of boost)
•Each fuel rail is fed individually for equalized fuel flow
•Billet fuel rails have a larger internal diameter for improved fuel flow
•Redesigned injector hood (internal portion of the fuel rail where the top of the injector receives fuel from) that offers much better clearance and flow.
•Allows fuel to flow to the injectors easily
This bolt-in kit is a direct replacement and upgrade to the factory fuel system and includes a completely new set of AAM Spec CNC Billet Aluminum Fuel Rails with a 500% flow improvement over stock, a complete set of –AN stainless lines and fittings (completely pre-assembled and pressure tested to greatly decrease installation time), Aeromotive 1:1 boost referenced fuel pressure regulator, fuel pressure gauge, and a full set of instructions with pictures for a straight forward installation. A must for any high-horsepower 350Z and G35!
You can give us a call to order 301.330.8835 opt. 4, e-mail us Sales@alteredatmosphere.com, or order online here
http://www.alteredatmosphere.com/mm5/merch...ct_Code=AAM35FR S&Category_Code=350Z_FS . If you order online the regular price will show, simply place your order and you will actually be charged the discounted rate!
Special Sale Pricing available only while quantities last and does not apply to previous orders and/or orders in transit/currently being installed.
Dave@Altered is offline
post #2 of 4 (permalink) Old 10-04-2006, 06:04 PM
Damn. That is a nice discount.
post #3 of 4 (permalink) Old 10-04-2006, 08:48 PM
teh215's Avatar
Send a message via AIM to teh215 Send a message via Yahoo to teh215
Link doesn't work.. What hardware is included?
teh215 is offline
post #4 of 4 (permalink) Old 10-05-2006, 11:54 AM
Here is the link: AAM Fuel System
The Fuel System comes complete with:
-Aeromotive 1:1 Fuel Pressure Regulator
-0-100psi Fuel Pressure Gauge for the Regulator
-Goodridge Stainless Braided Fuel Lines (pre-assembled, for leak-free & easy installation)
-Fuel Return Line
-Factory Fuel Tank Transfer System Retention Kit
-Two AAM Billet Fuel Rails
-Mounitng Hardware
Hope this helps,
Mike Mahaffey
2003 350Z 471rwhp
Best et: 12.7 @ 113mph
1994 Stealth Twin Turbo 751awhp
Best et: 10.71
Best mph: 137mph
HKS F-Con-Pro Certified
UTEC Sales & Tuning
GReddy E-Manage Sales & Tuning
Unichip Sales & Tuning
Split Second Tuning
ECU Flash (factory computer programming) Tuning
Coming Soon - AAM 350Z Fuel System Stg. 2 Upgrade (500-800rwhp!)
Coming Soon - AAM 350Z Ultimate Turbo Exhaust
Coming Soon - Project Ultimate Street Turbo 350Z
Mike@AAM is offline
